Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Trans Grind
Old 08-14-2011, 10:43 PM
Boost_Addict_88's Avatar
Default Trans Grind
My friend has an '04ish Accord sedan with an autotragic trans and in reverse (while shes backing up AND turning the wheel), there's an unpleasant grind (like metal on metal). I did a search, but couldn't find much. It doesn't do it in drive, just reverse. I checked the fluid and it looks/smells fine, so I'm stumped, but I think it might be a synchro (I don't know anything about autos), but I'm not 100%. Any info helps. Thanks.
Old 08-15-2011, 04:42 PM
Chiovnidca's Avatar
Default Re: Trans Grind
Brake pad sensor maybe?
Old 08-20-2011, 08:13 PM
I was informed that this issue occurs when in drive and turning the wheel. We're going to the stealership to see if they can't look at it.
Thanks for the reply!
Old 08-27-2011, 06:03 PM
mikeoxbigg's Avatar
i was told the other day that there is a recall on the 4 cyl. automatic transmissions you should try looking into that.
LS Turbo300
09-02-2012 10:34 AM
crash85
12-31-2011 10:05 AM
OneQuickNA
09-03-2008 07:25 PM
Probot
01-04-2008 04:22 AM
hondalite
10-30-2005 05:38 PM
Quick Reply: Trans Grind
