03-07 accord v6 not going into gear while car is running
so I have a j swap actually with a 03-07 transmission
but i have the TL shifter box and cables to it from a 06
it goes in gear correctly all gears when off, but when on it doesn’t...??
Does this have anything to do with the cables?
it is a brand new slave cylinder and new brake line, I bled correctly and noticed my clutch pedal is still spongy? But the fork on transmission went as far as it couldve(or so I think)
about half an inches of movement, should it be more? I tried to manually push the fork further and it won’t budge.
I hope I explained that as detailed as possible....
Re: 03-07 accord v6 not going into gear while car is running
if you replaced the master cylinder, make sure you have around a half inch of clutch freeplay
sometimes an air pocket can get stuck inside the rubber reservoir hose, you can pinch it up and down with the cap off while someone pumps the clutch to try to dislodge it
I have a full TL clutch set from flywheel to pressure plate if that matters.... welll the kit said it would work in both accord and TL 6 speeds, I do have an inche of play, would pedal free play make it not able to shift?
The car car has sat for 3 years ... possibly my master cylinder is bad? Even though it’s new but sat for 3 years?...
can an it be because of my clutch line, it’s not hard straight through, it’s a stainless steel flex line I guess,
Update: 4/1/2018
I found out my issue, I had replaced the master cylinder and didn't think it was the issue, Turns out it was the issue, I got a bad Replacement i suppose, defective.
Went back to AutoGay and got a new one, Works and goes into gear, So excited.
i normally use and exedy mc and an autozone sc, the autozone sc has a lifetime warranty and i've had times where the bleeder bolt will seize up and brake off but other than that it works fine
SlowCD5
11-09-2013 02:14 PM
