trouble going into reverse! help!
Old Sep 28, 2006 | 07:06 PM
artifact kills's Avatar
Default trouble going into reverse! help!
every day at least once i have trouble going into reverse it wont budge into gear, from nuetral or 1st, on flat ground. with foor on brake or off brake, but while not moving. anyone know what the problem is? I was thinking maybe clutch, i have a potenza flywheel, act clutch and b&m short throw. its the clutch right?
Old Sep 28, 2006 | 07:43 PM
LSRracing95's Avatar
Default Re: trouble going into reverse! help! (artifact kills)
could be a few things..
the first thing is, honda transmissions do not have synchros for the reverse gear.. usually it helps to "trick" the transmission into "thinking" reverse has synchros by putting the shifter into first gear and then quickly and smoothly shifting to reverse.
(at a dead stop) please dont do this while moving..
but, if this does not solve the case.. as it may not, i would check your slave cylinder for leakage, your master cylinder for leakage, and if it boils down to it.. maybe you could get a new clutch.. but you would sense the need for a new clutch with other gears as well, both while moving and at a stop.. more so on the move.
check your clutch slave and master cylinders first.. check around your clutch pedal for fluid inside the car as well.. good luck
Old Sep 28, 2006 | 07:46 PM
JasonST's Avatar
Default Re: trouble going into reverse! help! (LSRracing95)
If it doesn't go into reverse when ur car is on and only on then it's probly clutch related, but if it still doesn't go into reverse even when car is off probly not the clutch. Try what LSRracing95 said.
drbyers's Avatar
most excellent DIY advice LSR...
Old Sep 28, 2006 | 07:54 PM
slow_ls's Avatar
what I do is if I'm already going forward I will slow down to a point of almost stopped but with the car at a slight roll and then put it in reverse. It always works for me and I never grind.
Old Sep 28, 2006 | 08:06 PM
funny slow ls, you must write jokes for the funny comedians like jerry sienfled and carrot top. everyone else: thanks for the advise. i think there may be somthing leaking because ive been gettin fukin grease all over my shoes for no reason, i just htought it was maybe the carpet that was greasy
Modified by artifact kills at 9:30 PM 9/28/2006
Old Sep 28, 2006 | 08:31 PM
i just tried and it didnt shift into reverse the first few times while it was off.. so what could it be?
Old Sep 28, 2006 | 08:45 PM
slow_ls's Avatar
No I'm totally serious. Whenever my cars at a dead stop and I just try reverse it wont go, so I put in fourth then reverse and that always works, and you can't bag on the rolling technique intill you've tried it. And when I say slight roll I mean 1 mph which doesn't regester on the speedometer but is just my best guestimate. And seinfeld dont got **** on me.lol
jlowellintegra
Jun 18, 2011 11:43 PM
candy eg
Jan 11, 2006 08:22 AM
herbalist
Mar 25, 2005 07:59 PM
mdj_ge
Dec 3, 2004 06:45 AM
