Speed Sensor Questions
Hey there, I just replaced the clutch in my 2015 Accord EX 6-speed. It drives and shifts smoothly so everything is usable, but a few things are not working properly after I put everything back together.
First, my speedometer is not working. During the process of taking out my hubs I took out the speed sensors that stick into the hub. I made sure to put them back in and I didn’t stress the wires that were connected to the sensor at any time. It seems simple enough but is there something I needed to do to properly reinsert them or should I just buy new sensors...?
Second, when I was driving prior to the clutch change, if I drove fast enough, my shifter wouldn’t allow me to move into reverse. Now, I can be on the freeway going 65 and I can put it in position to pull it into reverse which freaks me out because it would be really easy to accidentally shift into reverse instead of 6th. Did I loosen something I need to tighten when I changed my clutch or can someone tell me if this is a product of the speed sensor not working as well?
Any information is appreciated
Re: Speed Sensor Questions
I believe this sensor is on the front of the transmission,by the radiator.
But I dont remeber for sure,Google is your friend here.
Kris05TSX
Transmission & Drivetrain
08-03-2019 08:37 PM
BeantownBeatdow
02-02-2011 02:26 PM
