wiper problem solved
Old Nov 30, 2008 | 07:45 AM
sghokie's Avatar
Default wiper problem solved
I thought I would share my findings.
My 97 accord wipers would only work when I would push down on the lever.
Turning the **** to any wiper speed would do nothing.
I tested the connector under the dash, got nothing so that meant bad switch.
I removed the switch by the steps outlined in the repair manual. No you don't have to remove the wheel and airbag. Only the switch comes out.
I found that 2 of the side clips that hold the switch together are broken making the switch loose contact inside. By pressing the switch back together it works fine. So a little super glue is all it needs.
crvpilot
Feb 26, 2018 06:55 AM
Mr.Death
28
Jul 13, 2011 02:41 PM
gregbaccord
Aug 21, 2008 11:36 PM
SR20 Inside
Jan 25, 2006 09:24 PM
ferio 95
Mar 3, 2005 04:47 AM
