Where is the thermostat located on a '96 Accord?
Old 01-03-2005, 09:14 PM
jaygtyj's Avatar
Default Where is the thermostat located on a '96 Accord?
Please be very detailed in your description. Also, how hard is it to change?
Thanks.
Old 01-03-2005, 09:19 PM
Carolina Fried Rice's Avatar
Default Re: Where is the thermostat located on a '96 Accord? (jaygtyj)
look at the radiator hose, follow it until it gets to the block. Thats the thermostat housing. Not hard to replace either.
Old 01-04-2005, 07:47 AM
Filthy Focker!'s Avatar
Default Re: Where is the thermostat located on a '96 Accord? (TSAF22B1)
Top hose of the rad going to the block.
Remove the bolts, pop out the thermostat. Some coolant of course will leak out but not to worry. Scrape off old gasket completly.
Install new gasket. You can use a couple of dabs of grease to hold it in place if it moves on you. Then install thermostat RIGHT SIDE UP. Reinstall bolts. Turn car on look for leaks and top up fluid.
fs
TheeInitiative
03-24-2014 02:50 PM
fomococo
07-17-2012 05:39 PM
azandford
05-18-2010 07:46 AM
97hosein
07-27-2006 06:00 AM
jdm555
13
03-12-2004 08:24 PM
Quick Reply: Where is the thermostat located on a '96 Accord?
