What else to replace when doing timing belt replace?
Re: What else to replace when doing timing belt replace? (Seungho.K)
While it is getting ripped apart, check for seal leaks? Or check valve lash and clearance.
Re: What else to replace when doing timing belt replace? (awdgsx96)
The accessory belts you'll be removing.
Buy the OEM Honda timing belt kit from TAS Auto and the two tensioner pulleys and you'll be set.
You'll need to find a metric feeler gauge for the valves if you want to do that as well.
balancer shaft seals, cam seals, balancer shaft seal retainer (if not installed or if recommended for your model), crank seal, oil pump gear housing seal, timing cover seals, valve cover gaskets & tube seals & grommets, drive belts.
H-T Order of Merit
Re: What else to replace when doing timing belt replace? (Secret Chimp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Secret Chimp »</TD></TR><TR><TD CLASS="quote">You'll need to find a metric feeler gauge for the valves if you want to do that as well.</TD></TR></TABLE>
uh, no. You can use any set of feeler gauges to check the valve lash. The manual provides the numbers in both standard and metric. And if for some reason you only have the standard or metric values, divide the metric value by 25.4 to get the standard equivalent or if you only have the standard values then multiply it by 25.4 to get the metric equivalent.
H-T Order of Merit
Re: What else to replace when doing timing belt replace? (aasaa666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aasaa666 »</TD></TR><TR><TD CLASS="quote">... oil pump gear housing seal, timing cover seals ...</TD></TR></TABLE>
I would only worry about the oil pump seal if it's leaking. And the timing cover seals aren't a big issue so I would only replace them if they were ripped up or not there at all.
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seungho.K »</TD></TR><TR><TD CLASS="quote">all i can think of is water pump and tensioner, any other recommands?</TD></TR></TABLE>
-the accessory belts, it's a good time to replace them.
-the water pump.
-the timing and balancer shaft belts.
-For the cost of the seals (cheap), I would just replace the cam, crank and front balance shaft seals. Even if they aren't leaking, it's not worth having them start leaking between now and the next timing belt change.
-I generally change the tensioners just to be sure, but you dont really need to if they are still spinning nice and smooth.
-the valve cover gasket set
Thats all I can think of right now but I did lists of both parts and tools for this job in my write-up that can be found in the FAQ.
-the water pump.
thumper64
12
04-24-2011 12:33 PM
98savage
06-14-2007 03:52 AM
99_dc2
10-01-2005 12:43 AM
confucius
01-24-2005 08:08 PM
