weird squeaking... anyone esle has that problem?
My car started sqeeking awhile ago, very unnoticably, when i hit a bump here and there. The sound is coming from the driver's side front wheel area. Now, its hot outside and with the windows down... this little sqeeking is starting to **** me off. Its gotten louder, and sqeeks more aften. Little history: Car has eibach pro kit, with kyb agx shocks. The setup is like 6 months old. So its not the shocks. Sway bar end link bushings have been replaced last week. Both tie rods have been replaced yesterday. Sway bar bushings been replaced 2 weeks ago. Everything been lubricated with grease, and old components sprayed with silicone lube. It still sqeeks. Only thing thats left are upper and lower control arms. And the fork. I'm tired of changing things and still having that sqeeking. Anyone knows what it is for sure?
P>S> the best part is that it squeeks only on the ground with the wheels off. So when its on the lift no one can pin point it.
Re: weird squeaking... anyone esle has that problem? (ZexyAccord)
It may be your a-arms rubbing on the inside fender well, that was the problem with my brother's civic and with a little bit of grinding the problem was alieviated. Just a possibility.
Re: weird squeaking... anyone esle has that problem? (SpeedFreak77)
i figured it out, it ended up being a rotor shield scraping on the hub! Would have never guessed cuz sounded like a spring or a rubber sound. But anyway, i fixed it! Yeah!
Re: weird squeaking... anyone esle has that problem? (THEROPE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
what would cause the rotor shield to bend? hard driving
