wats better the f22b1 or f22b2 are thay the same?
? wats better the f22b1 or f22b2 are thay the same?
Need help befor i buy. I found a f22b1 v-tec but i was looking for the f22b2 v-tec are thay the same cuz that would make this easy?
H-T Order of Merit
Re: (tru_superman_xXx_24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tru_superman_xXx_24 »</TD></TR><TR><TD CLASS="quote">?what i had an ex v-tec an i swear it said f22b2? </TD></TR></TABLE>
Do you have a DX, LX or EX Accord?
If you have an EX, maybe someone swap the blocks for whatever reason? The previous owner maybe? Maybe someone messed up the original F22B1 block and swapped in the F22B2 block as a replacement. The stamping on the block would say F22B2 but the valve cover would says VTEC.
If you have a DX or LX, then maybe someone did a VTEC head swap?
IDK, just a thought.
1 Post
Re: (chomorro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chomorro »</TD></TR><TR><TD CLASS="quote">k im confused on what the heck i have in my 98 accord. Mine is LX 5spd vtec engine. Is that an f22b2?? i can go look i guess but im working </TD></TR></TABLE>
no, yours is an F23A something.
B1 was a 94-97 EX
B2 was a 94-97 DX/LX/SE
B1 was a 94-97 EX
Re: (Intense2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Intense2.2 »</TD></TR><TR><TD CLASS="quote">Either way your still slow as a ****, stop wasting your time & get an H.
End of Topic. </TD></TR></TABLE> so that he can still be slow as a **** but have wasted 3k on getting the jdm H in his car.
New User
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tru_superman_xXx_24 »</TD></TR><TR><TD CLASS="quote">? i think wont a f22b1 with h22a1 lsd trans ? + turbo
or is the h22a swap just that good?</TD></TR></TABLE>
those gear ratios with an f22 will be crazy short and if you add a turbo, all you will get is wheel spin until maybe 3rd or 4th gear...save the money you would have spent on an h22 lsd motor, buy a phantom grip lsd for the stock transmission and get it installed (it's not the best lsd, but it does the job and does it well)...
i'd say you have quite a bit of research to do before you ever think about turboing a motor, though...start searching for posts regarding turbo f22's and go from there...
Location: Free bullets if you find me sucka, Washington
1 Post
Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote">
Maybe it was a f22b2 head + vtec valve cover? or something like that?</TD></TR></TABLE>
the valve covers are non interchangable...F22b1 have the spark plugs up front and F22b2 have em farther back
