VTEC-E to VTEC?
Old Oct 27, 2013 | 10:12 PM
MattDula17's Avatar
Default VTEC-E to VTEC?
Hey guys,
So I have the F22B1 engine in my Accord, and I have learned that this is an VTEC-E engine. I would like to convert it to simple VTEC and basically say **** the extra gas mileage. Is this just something that I tune out, or do I have to do any rebuilding in the engine itself??
Old Oct 28, 2013 | 02:26 AM
Shmallow's Avatar
Default Re: VTEC-E to VTEC?
what's the difference between VTEC and VTEC-E? what makes the F22B1 VTEC-E?
Old Oct 28, 2013 | 06:57 AM
chrisnick's Avatar
The cam.
Old Oct 28, 2013 | 07:52 AM
accordhybrid's Avatar
The F22b1 was not a Vtec-E motor......honda used Vtec to help improve gas mileage in the Accord.
Vtec-E was first introduced in the Civic VX and HX models.
Old Oct 28, 2013 | 10:13 AM
Shmallow's Avatar
improved gas mileage translates to Economy. VTEC-E is VTEC-Economy.
Honda may not have marketed it as "VTEC-E" like they did for the Civic VX & HX but the function is virtually the same. One intake valve used at low RPM both valves open the same in "VTEC" mode at higher RPM.
to answer your question directly, you can have the camshaft reground to a more aggressive profile. This will have the same effect as what you're talking about. with a tune you may see 10% improvement... maybe.
to me it sounds like what you would be happy with is a "G22" hybrid build or a twin cam cylinder head swap from an H22. This will give you real DOHC VTEC... and better ports, better intake manifold... do some looking around here in the forums, especially the Hybrid forum and both Accord and Prelude forums. there are several guys who have done this conversion.
Old Oct 28, 2013 | 11:58 AM
NZXTInerTia's Avatar
Tune. I can literally show you where it boosts up the horsepower after it starts to slug down.
Old Oct 28, 2013 | 01:26 PM
GhostAccord's Avatar
You need to instal a custom camshaft and a have it tuned. As those are the two things that makes it an economy VTEC. The F22B1 and F23A* have two different sized primary cam lobes. This makes it so that one of the two intake valves only opens slightly when out of VTEC.
I wouldn't waste your time with any sort of hybrid build. What people like to call G builds. You would be better off doing a complete H22/F20 swap if you want 40hp of real VTEC.....lol
Old Oct 28, 2013 | 09:54 PM
holmesnmanny's Avatar
it may not have been stamped with vtec-e but this is definitely a vtec economy motor
Old Nov 5, 2013 | 12:33 PM
MattDula17's Avatar
Yeah, im not looking for too much of a gain. I would be happy to boost my numbers from 145 to 165-170. Any more is just a bonus! Which option is more cost effective? VTEC conversion and tune, or a G22 hybrid build?
Old Nov 5, 2013 | 01:28 PM
You can't convert to VTEC, you engine is already VTEC. The CAM itself is a more "relaxed" cam aimed towards fuel economy (as with the tune). To get "my vtak kicked in yo!" VTEC you will need a more aggressive regrind cam and a tune. If its an automatic, forget about it.
rawrjaay
Sep 2, 2011 05:59 PM
george34
24
Dec 29, 2005 05:41 PM
zapps
Aug 1, 2004 02:34 PM
japrex
Jun 12, 2004 08:19 PM
jonesin4abeer
14
Sep 23, 2003 07:16 AM
