valve problem
Old Dec 1, 2012 | 12:19 PM
paysos's Avatar
Default valve problem
ok so here it is, i have a 93 accord with the f22a motor in it. I was getting oil in my spark plugs and decided to replace the lower tube seals. I replaced everything the car started and ran fine for a few minutes then it started making loud clanking noises coming from the cylinder head. i turned the car off right away took the valve cover off and manually cranked it. when i did that i noticed the number 3 and 4 cylinder rocker arms popped up from the exhaust side so thats where the noise was coming from. Now my question is do i have bent valves? i noticed that the valve stem doesnt exactly sit on the center of the rocker arm. Any help would b appreciated!!!!!
Old Dec 1, 2012 | 12:47 PM
GhostAccord's Avatar
Default Re: valve problem
Sounds like you probably bent a couple valves. The tips of the valve stem should be lined up.
Can you post up some pictures?
Old Dec 1, 2012 | 12:54 PM
paysos's Avatar
I'm on my phone let me know if u can see it
Old Dec 1, 2012 | 01:14 PM
That looks out of alignment. However, it could be that it's out of adjustment.
When you adjusted the valve clearances after re-installing the rockers. What specs did you set the clearances to?
Next step would be to find someone with the gear to do a leak down test and see if that valve is passing.
Old Dec 1, 2012 | 01:17 PM
paysos's Avatar
exhaust valves .012 intake valves .010 the #1 and #2 cylinders look good 3 and 4 on the exhaust side are the ones making the loud popping noise coming up the picture is from the #4 cylinder
Old Dec 1, 2012 | 01:18 PM
paysos's Avatar
should i even bother trying to adjust it further or is it time to rebuild the valvetrain?
Old Dec 1, 2012 | 01:26 PM
You could try adjusting it again. I would also do a leak down as well before you start tearing the head off to do a rebuild.
Old Dec 1, 2012 | 01:27 PM
paysos's Avatar
ok cool i'll do that thanks
Old Dec 3, 2012 | 12:48 PM
paysos's Avatar
Ok so I went back n redid all the adjustments and everything checks out good, but what I did notice was that it seems like the valves are sticking closed then popping up open any idea y that could b???
Robotoyaki
Jan 1, 2010 02:10 PM
pentaq
Apr 19, 2006 01:51 PM
Pineapple Devil
Dec 28, 2002 08:28 AM
GreenD
Apr 25, 2002 07:30 AM
raene
Jun 27, 2001 10:45 PM
