Understeer
Old Apr 20, 2012 | 06:44 AM
LM1092's Avatar
Default Understeer
I have a 2002 Honda Accord and I'm looking to Reduce Understeer by ether adding more Oversteer or going for Neutral
What is the best way to do this?
Old Apr 20, 2012 | 12:05 PM
75aces's Avatar
Default Re: Understeer
Go with a wider tire. I am using 195 on 15x7 and you could lower the car. Install front strut bar and anti roll bars.
Old Apr 20, 2012 | 02:40 PM
bakerskater11's Avatar
It'd help if we knew what application this was going towards, Autocross? street? I can't imagine having too many issues on the street. Oversteer might be a bit difficult to get in a fwd car just from my experience with circle track.
If it's a strictly track car, a bit of camber in the front might help reduce the understeer but it will unevenly wear the tires. I know there was a EF civic hatch who raced with us a few times and she cut the strut towers a little bit to pull the top of the struts in the front and rear inward to give it some more camber, so it's possible to do it on all 4 wheels.
I don't know if this would do much, I race a mustang so it's a whole other world...but just another suggestion to add on top. I think making the car more rigid and solid like aces said with lowering springs/sway bars will produce what your looking for. It's a world of difference when your car is lowered
Old Apr 20, 2012 | 03:12 PM
m_shake's Avatar
Big rear bar, big rear spring rates, and the widest tires you can fit.
Old Apr 21, 2012 | 11:26 AM
LM1092's Avatar
Most likely Autocross
I've heard if you get a thicker sway bar in the back and a thinner in the front it would help too... Is this True?
Old Apr 21, 2012 | 11:56 AM
75aces's Avatar
Experiment and see what you like. Its a combination of tires, sway bars, anti roll bars. Its all about the geometry of your setup.
Crx_Civic
May 31, 2007 07:04 PM
94c1v1cex
May 23, 2007 02:46 PM
ak47autolock
May 31, 2006 05:12 PM
Ninja Mike
17
Jul 28, 2005 05:29 PM
sneakypete
Jul 10, 2004 04:05 PM
