tps sensor
Old Feb 25, 2011 | 12:59 PM
dfbdavid38's Avatar
Icon3 tps sensor
hello i got a 93 accord 2.2 ex i thought my tps sensor was bad because when it was pluged in it would run really bad after up got up to speed so i unpluged it and it ran fine so i replaced it now with the new onw one the car still has the same problem run bd when pluged in unplug it it runs good does anyone know what is going here and how to fix it thanks
Old Feb 25, 2011 | 02:46 PM
phootbag's Avatar
Default Re: tps sensor
Confirm the reference voltage is around 5 volts, the signal voltage is around .45 volts with throttle closed and around 4.5 volts wide open, confirm no voltage drop on ground circuit.
Old Feb 25, 2011 | 04:27 PM
dfbdavid38's Avatar
please explain to me how to do this and what is ground volts
Old Feb 25, 2011 | 11:46 PM
nus_dogg's Avatar
You need to use a voltmeter. You just keep switching your leads on each wire til you find that there's .45v while the throttle body is closed. Then with it open, it should read 5v.
Old Feb 26, 2011 | 03:33 AM
dfbdavid38's Avatar
well it reads 5 volts all the time i dont get a .5 and the tps is new so whats going on here i have moved it and still get the same reading
Old Feb 26, 2011 | 09:28 AM
poorman212's Avatar
Can we back up just a bit. First, how did you test the old tps to be sure it was bad-besides just unplugging it. Are we chasing the wrong issue? What if any codes do you have?
Also, I think there are three wires on the TPS. What are you getting on the other two.
Old Feb 26, 2011 | 09:45 AM
dfbdavid38's Avatar
Icon3 Re: tps sensor
i checked it like the honda mannel told me i get 5.4 volts all the time in the plug well the sensor you can move it and nothing on the volts will change so why do i have 5.4 when there should only be .5 volts
Old Feb 26, 2011 | 05:16 PM
dfbdavid38's Avatar
Icon3 tps-2
ok now i have checked my tps plug i got gound on the green and .5 on ther yellow now when i turn on the switch i lose my ground whats going on here it on my 93 accord 2.2 anyone know whats going on here do i have a bad switch or a bad ground
gripek
Honda S2000
12
Feb 22, 2012 10:08 PM
chrisff521
Apr 5, 2009 07:26 PM
92prelude23
Jan 26, 2009 05:43 PM
deucedeuceEK
Apr 27, 2007 02:39 PM
