Timing Issue
Old May 18, 2011 | 07:07 AM
Skitso's CB7's Avatar
Default Timing Issue
If the timing belt on a F22a6 jumped 4 teeth at idle do you guys think there would be any bent valves? I just changed the head and I dont want to have to pull the head back off just to look at the valves. I figured I could just reset the timing and be good to go since it jumped only at idle. The car was idling fine for about 20 mins until it jumped timing then it cut off. Any ideas?
Old May 18, 2011 | 05:17 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Timing Issue
Originally Posted by Skitso's CB7
Any ideas?
Reset the timing belt, warm engine up, do compression check.
Old May 18, 2011 | 09:52 PM
nus_dogg's Avatar
^^^ x2!
Old May 20, 2011 | 12:20 PM
will do! i plan to work on it Sunday so i should have results then. Ill be back! Thanks!
chipper
10
Jul 4, 2013 10:59 AM
Powered by VTEC
Jan 25, 2008 10:13 AM
Y2KCivicSiR
May 9, 2005 09:56 PM
spyderracing
Aug 27, 2004 08:39 AM
