What are the symptons when timing is off ??
Old 01-25-2008, 05:46 AM
Powered by VTEC's Avatar
Default What are the symptons when timing is off ??
i think i might have messed up the timing when i replaced the cams. and now it idel and sounds like a disel engine. cranking sound and ticking sounds. so i am just wondering what are the symptons when timing is off.
There is no CEL
thanks
and i need to get timing right before i can do the valve adjustment again.
Old 01-25-2008, 08:51 AM
austinkli's Avatar
Default Re: What are the symptons when timing is off ?? (Powered by VTEC)
sounds like just described about half of them.
Old 01-25-2008, 09:19 AM
HRD PKR
B16B_coupe's Avatar
Default Re: What are the symptons when timing is off ?? (austinkli)
Poor idle, Sound like its missing(cause its off a tooth), wont come off idle, The ticking is prob the valves out of adjustment. put it back in time
Old 01-25-2008, 09:20 AM
Syndacate's Avatar
Well did you double check the belt timing?
Also, did check the dizzy timing again?
Also, how aggressive are the cams you put in there? Too aggressive and you'll start to pick up overlay - at stock compression ratio that'll kill ya.
Symptoms when timing is off:
- Car runs like ****, often is described as sounding like a subbie.
- Bad power or not enough
- Bent valves creating not power
So on and so forth...
EDIT:
Make sure your timing belt is 100% - it could be off by one tooth which would cause what you're describing.
If you're positive the t-belt is on 100%, and you checked the distributor with a timing light and it's perfectly aligned - then I wouldn't worry about it - it could be sounding different depending on how aggressive the cams were.
Old 01-25-2008, 09:51 AM
Default Re: What are the symptons when timing is off ?? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
i only put in a oem ITR intake cam.
Old 01-25-2008, 10:13 AM
b17boost's Avatar
u can also check your vaccum, i believe if it is somewhere around 10in. HG ur off time, someone correct or verify
Skitso's CB7
05-20-2011 12:20 PM
ascarberry
04-21-2011 03:46 PM
hondachris1994
07-19-2007 08:50 PM
Y2KCivicSiR
05-09-2005 09:56 PM
CIVIC96DXcp
04-19-2005 07:47 PM
Quick Reply: What are the symptons when timing is off ??
