TACHOMETER PROBLEM
Old Jun 21, 2004 | 07:37 AM
joey_knuckles's Avatar
Default TACHOMETER PROBLEM
I have a 96 Accord LX -V6 (AUTO). It has 61,000 miles. I just recently drove it 1600 miles with no problems at all on a trip. A week later I noticed that my RPM Tach was going crazy (jumpming up and down) while I was driving or it will not move at all and it just sits at Zero while the car is moving. My bigger concern is that when the Tach seems to be malfunctioning, the car also seems to jerk periodicly but when the tach is working fine the car drives fine. The check engine light is not on. What could be the problem??????
Modified by joey_knuckles at 9:11 AM 6/21/2004
Old Jun 21, 2004 | 08:30 AM
Default Re: TACHOMETER PROBLEM (joey_knuckles)
bump
Old Jun 22, 2004 | 08:12 AM
anybody???????
Old Jun 22, 2004 | 10:07 AM
biggs2.3's Avatar
sounds like your tach is busted noob
Old Jun 22, 2004 | 02:31 PM
Default Re: TACHOMETER PROBLEM (biggs2.2)
ok, but would that cause the car to jerk while i am driving it
Old Jun 22, 2004 | 02:44 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggs2.2 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your tach is busted noob</TD></TR></TABLE>
way to give helpful information
Does the engine rev with the tach like does it bounce from 1K to 2.5K or just the tach?
If that is the case it might be your tachometer. Are you getting a CEL (check engine light)?
Old Jun 22, 2004 | 03:34 PM
Default Re: TACHOMETER PROBLEM (VRDrvr)
the engine does not rev with the tach. half the time the tach just sits at zero(while driving). the CEL did come on, but then i pulled the fuse to reset it and it has not came back on since(2-3 weeks), mind you all this time i have been having the same problem with the tach.
thanks in advance for any advice
Old Jun 22, 2004 | 03:35 PM
The_Todd's Avatar
Farts in the shower
Hmmm next time you get the CEL pull the code and see what it is
Usually that is a good indicator of what is wrong
Old Jun 22, 2004 | 03:46 PM
I had the code pulled at AutoZone. I dont remember the # but it said "Engine Speed Sensor"............
Old Jun 22, 2004 | 07:56 PM
cmrvi1's Avatar
Your coil is going bad. The tach gets it's signal from the coil, that's why it jumps.
But the telltale sympton is the fact that the engine jerks sometimes.This means that the coil is weak.
Old Jun 23, 2004 | 01:32 AM
david90's Avatar
I 2nd the coil. It happened like you've explain to me and it was fix by replacing the coil. Coil problem is common among 5th gen v6 accord.
Old Jun 23, 2004 | 04:40 AM
Default Re: (david90)
thanks guys.
Modified by joey_knuckles at 1:23 PM 6/23/2004
Old Jun 23, 2004 | 12:42 PM
Default Re: (joey_knuckles)
where is the ignition coil located? and how hard would it be to replace myself?
Old Jun 23, 2004 | 12:53 PM
david90's Avatar
COil is located under the distrubutor. You'll need a 10mm wrench. SImply unplug the old and plug in the new coil.
If you drive with the old coil long enough, CEL will come on
Old Jun 24, 2004 | 07:44 AM
I just replaced the coil and I am still having the same problems........
any suggestions
Nihilus
Dec 18, 2005 01:28 AM
AMChev
Nov 1, 2005 05:49 AM
sit220
Jun 13, 2004 04:07 PM
sir168
Mar 15, 2004 06:09 PM
Boostless97Lude
May 12, 2003 08:47 AM
