steering problems? help please!
Old Feb 22, 2009 | 06:48 PM
mkrieger500's Avatar
Default steering problems? help please!
Well my problems continue. I don't know whats wrong with my car any more. Again I have a 1993 accord ex 4dr. The steering wheel is still shaking while i brake but I have pretty new rotors on it as well as new pads, main bearings, upper and lower ball joints, tie rod ends, and now new calipers on both sides. Tonight, it did something else. When I turned hard right I let off of the steering wheel to let it come back left. It came back but it was shaking and the pulled left on its own with the steering wheel still shaking. There is also a knock when I make hard turns. I can't tell from what side but its kind of loud and you can feel it in the wheel. Its almost like something is slipping.Any thoughts are much appreciated! Thanks again!
Old Feb 22, 2009 | 06:53 PM
xhondaaccord92x's Avatar
Default Re: steering problems? help please!
cv axle is bad...thats the knock on hard turns and if its not aligned right the shaking while driving
Old Feb 22, 2009 | 06:59 PM
Have you heard of these things happening to others yet? And how can you check witch one or both?
Old Feb 22, 2009 | 07:07 PM
grab the shaft of the axle and pull it side to side and up and down...if theres alot of play its bad. is it only doin it turning one way or both...
Old Feb 22, 2009 | 07:11 PM
If you mean turning then yes i believe its doing it when i turn both ways. Would this explain the shaking while braking or not and while driving/accelerating?
Old Feb 22, 2009 | 07:16 PM
khronicboy420's Avatar
have you checked your tires if you have bad tires that could be the vibration and just because you have new brakes doesnt mean that they could not have got REALLY hot and warped a little. or maybe you have alot of brake dust on your rotors. so i would say double check your rotors and maybe replace your tires
not so much for braking but very possible and as for accelerating yes deff. ur putting a load on the axles. r they klunking when turning,accel, or braking?
and for sure your cv axle is bad
Old Feb 22, 2009 | 07:20 PM
The clunk is when i turn. The tires are fairly new and were just balanced. They have about 40k on them. I still need to figure out the braking shake though. The rotors were a "u know what" to get out and off of the car. If i replace the cv axles i might as well have them turned or replace them i guess.
Old Feb 22, 2009 | 07:23 PM
how many miles r on the rotors and did u break them in...u can check to c if ur rotors are warped before all that and as far as having them turned...some shops have on car brake lathes so the rotors dont have to come off...but im gonna stick to the axles
Old Feb 22, 2009 | 07:27 PM
The rotors were done about 5 to 10k miles ago. Not sure what you mean by breaking them in? Could you explain?
Old Feb 22, 2009 | 07:33 PM
they say ur not supposed to do any hard braking or slam on ur brakes for about the first 100 miles after new rotors are installed... after they get that hot and u come to a stop and sit the rotors warp...but after the miles the rotors go through many heat cycles which makes then harder just like hardened metals
Old Feb 22, 2009 | 07:39 PM
TheMuffinMan's Avatar
He knows where you live!
Axles & Tires
This is my opinion. When did you last get an alignment?
I kind of thought that might be what you meant. wasnt sure though. If there is any more advice for me from anyone let me know! Thanks! I will inspect my axles and check my rotors. My dad and i recently checked them with a dial indicator and they werent really uneven. Any ideas? I got an alignment after i did all those repairs from the first post. 4-6 months ago.
Old Feb 22, 2009 | 07:44 PM
im stayin with axles or tires too...as for the tires they can be in balance but have lumps or bad belts in the tread area
Old Feb 22, 2009 | 07:58 PM
You *may* want to take it to another place to get the alignment checked, some places can do a really shotty job at aligning a car. Try to get a computer printout of the before/after specs.
Warped rotors shouldn't do that while driving around, just under braking. I'd stick with the axles being funky, the tires having internal issues, and an alignment.
Are you getting quality tires or are you getting the $50 bargain ones?
Old Feb 22, 2009 | 08:02 PM
I got yokahoma tires. They were 80 bucks a pop. I don't know if they are bad tires. I know they are a big racing tire brand. What do you have for tires? Any recomendations for some all seasons. The ones i have are horrible horrible winter tires.
Old Feb 22, 2009 | 08:13 PM
You should be fine with yok tires. I have some Goodyear ones. I would recommend you a tire site but mine closed doors thanks to the economy haha.
It's possible you just got some that had been sitting around awhile or something. The other thing to make sure is that your wheels are balanced, I know I have one with a slight dent that will shake the steering wheel regardless of alignment.
Old Feb 23, 2009 | 06:36 PM
Cool thanks i will check into all of this! Thanks everyone! great help as always!!!
lildragon'07
13
Jun 2, 2010 08:31 AM
rachonda
Jul 5, 2007 06:54 PM
jpopson43
Apr 20, 2007 05:41 PM
RXM
Oct 7, 2003 08:00 PM
