starting and stalling problem
Old Jul 19, 2006 | 11:34 PM
Jmumblez2001's Avatar
Default starting and stalling problem
i have an 94 LX, 5 speed sometimes when i turn the key trying to start it rotates and not wanna start. i have to let sit for a few for to start. I'm thinkin ignition swtich. Any ideas......
Old Jul 20, 2006 | 03:45 AM
Ross 2.0's Avatar
In a Junkyard near you.
do you turn the key to "on" and wait for the check engine light to go off before starting it?
Old Jul 20, 2006 | 09:37 AM
Default Re: (MooGoCow3)
yup, and it would rotate and rotate not fire UP! let it sit for a few and fires up. also gotta play with the key switch for it to start.
Old Jul 20, 2006 | 02:45 PM
Mangotreemechanic's Avatar
Default Re: starting and stalling problem (Jmumblez2001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jmumblez2001 &raquo;</TD></TR><TR><TD CLASS="quote">i have an 94 LX, 5 speed sometimes when i turn the key trying to start it rotates and not wanna start. i have to let sit for a few for to start. I'm thinkin ignition swtich. Any ideas......</TD></TR></TABLE>
Pretty much sounds like your ignition switch. That is why it sometimes starts if you play with the ignition switch at the key. When you start it, it might catch for a fraction of a second, then die completely. At that time, the instrument panel also goes out, you might not have noticed before. If that is your symptom, try this test, turn your key to start the engine, but hold the key slightly back (less forward rotation) the moment after the starter motor turns the engine over. If it keeps running then it is your ignition switch. Sometimes the switch can be repaired by a DIY job.
Old Jul 22, 2006 | 11:32 AM
Default Re: starting and stalling problem (Mangotreemechanic)
well, i have read about the dash lights going out part, but mine has never done it. I do remember once i turned the key the III position (without actually turning the key and holding it) and it just fired up!. i found that odd. but anyway i hope that's the problem cause i'm getting ready to buy the part. if it's not i'll be pissed.
thammks for the input.
EF_LSVtec
10
Jan 27, 2017 04:36 PM
88_hatch_ls
Sep 2, 2013 12:25 PM
itslogz
Apr 4, 2010 08:21 PM
StreetRiot_DRE
19
Jul 26, 2008 10:25 AM
NXAccordTO4B
Sep 10, 2002 05:34 PM
