starting problems
Old Apr 8, 2012 | 04:40 PM
KiasSan's Avatar
Default starting problems
when starting my 93 accord ex, the start sounds like its just winding but there is no cranking, sometimes i have to like superwind, or try to crank again while the starter is slowing down, ive been told it could be my soleniod, any ideas on what it could be???
-Kias
Old Apr 8, 2012 | 06:14 PM
mitchk90's Avatar
Default Re: starting problems
Manual or Automatic? sounds like the starter is on its way out. I assume you mean you sometimes have to "flick" the key to get the starter to catch?
Old Apr 9, 2012 | 08:39 PM
KiasSan's Avatar
ya i have to have it catch, and really? and manual ( i hate autos xD) any ideas on anything else it could be?
Old Apr 10, 2012 | 02:21 AM
drcSyntax's Avatar
Aside from a bad battery terminal, or curroded or loose. I would think the starter as well.
Old Apr 12, 2012 | 12:01 AM
KiasSan's Avatar
Now my accord seems to be starting fine, but after a tad of driving i hear a grinding sound, like a metal to metal coming from the clutch area, i just had the clutch replace and the flywheel resurfaced in about december...
Old Apr 12, 2012 | 12:42 AM
joec44's Avatar
Clutch replasment says it all 1 starters bolts are loose or flywheel is loose/ bad. Check the start. bolts NOW
Old Apr 12, 2012 | 09:57 AM
dailydrivencd5's Avatar
In my experience, definately a starter issue. Starter could be shifting on turnover, check and bolts. I believe 3 14mm heads. If strapped for cash, get a reman. starter. But you et what you pay for. Btw might as well check the plugs, wires and distributor cap/rotor. Wouldn't hurt, good luck man.
Old Apr 12, 2012 | 09:58 AM
All* & get* my bad.
Untouchable13
Honda Civic (2001 - 2005)
15
Jun 10, 2009 01:55 PM
dominate9
Jan 16, 2009 04:32 AM
crxcess
Dec 3, 2006 03:30 PM
eg_coupe94
May 4, 2006 08:39 PM
RiCE On IcE 2
Dec 15, 2005 10:38 AM
