Starting problems
Old Apr 11, 2007 | 07:00 PM
rico892002's Avatar
Default Starting problems
Hi i have a 95 accord ex and i just put a new starter becuz the old one went out, anyways when i put the new starter on it started then i went in the house, aand came back the starter was clicking again..... what do u guy's think the problem is.The ignition switch or what. I check all the wires goin to the starter to the battery, i don't kno what it is help please
Old Apr 12, 2007 | 03:59 PM
hondadude's Avatar
Default Re: Starting problems (rico892002)
Aftermarket battery cable connectors can corrode at the connection point of the cable.
Don't just look at the connections. Clean them and be sure they are tight.
Power and ground side
Old Apr 12, 2007 | 04:51 PM
Integra_drk's Avatar
Default Re: Starting problems (hondadude)
is guessing its just a remanned starter? Take it to advance auto parts or somewhere similar and have it bench tested. If it works, its somewhere else in the charging system. Like ^^ he said, check the cables all the way up, corrosion doesnt always just occur at the terminals. And check your grounds.
dennisme41
Nov 13, 2017 04:40 PM
jimmy winn
Jan 26, 2015 07:57 PM
tsjeff
Feb 28, 2010 10:43 PM
liquid51
Jun 29, 2003 11:56 AM
l
Jul 31, 2002 04:37 PM
