starter
Old Nov 4, 2017 | 10:29 AM
dennisme41's Avatar
Default starter
1998 Honda accord wont start do I need a starter?
Old Nov 4, 2017 | 10:58 AM
theYBLEGAL's Avatar
Loved
Default Re: starter
Maybe, but there are more items to the system to check.
Find a Haynes or Chilton manual at your local auto parts store for more info
Old Nov 6, 2017 | 09:59 AM
Mason Edmison's Avatar
Default Re: starter
I would first check the battery with a multimeter, should read 12.6 with the car off. You can also check by checking to see if your headlights are bright and your wipers work as they should. Next I would confirm that the starter is getting power. You will want to check the cable from the battery to the starter. Positive on the terminal on the starter and negative on battery ground. You will also want to check the other cable on the starter- cable with the spade wire. I wouldn't buy a starter on a hunch. They are not cheap
Old Nov 13, 2017 | 04:40 PM
tamboo's Avatar
10 Year Member
Default Re: starter
you could inspect the starter solenoid contacts for wear.
rebuild kit is cheap:
https://www.ebay.com/itm/Starter-Sol...hZXh58&vxp=mtr
Adam1479
Jun 30, 2014 11:13 AM
lilsol89
Jan 5, 2009 03:57 PM
rico892002
Apr 12, 2007 04:51 PM
liquid51
Jun 29, 2003 11:56 AM
l
Jul 31, 2002 04:37 PM
