Starting Problems
Old Sep 19, 2005 | 01:39 PM
Alibi86's Avatar
Default Starting Problems
This is a very broad problem but i want suggestions on what could cause this problem? When i start the car it has a hard time starting, it sounds like it is about to die but then it catches itself and starts up. This only happens when i am starting the car for the first time that day. I replaced plugs/wires and the distributor cap. I tested my battery and it is fine. What else could it be other then the starter itself?
95 Accord LX AT
Old Sep 19, 2005 | 01:59 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Starting Problems (Alibi86)
Dirty fuel filter??
Old Sep 19, 2005 | 02:59 PM
Alibi86's Avatar
alright, anything else? I am going to check the fuel filter and the regulator.
Old Sep 19, 2005 | 03:39 PM
BLKFLSH's Avatar
Default Re: (Alibi86)
Fuel pump. Hope not it's a bitch to remove the gas tank and even worse to replace the gas tank.
Old Sep 20, 2005 | 07:52 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alibi86 &raquo;</TD></TR><TR><TD CLASS="quote">When i start the car it has a hard time starting, it sounds like it is about to die but then it catches itself and starts up.</TD></TR></TABLE>Do you mean the starter cranks the engine & slows down a bit, before the engine fires? That sounds like it has to go back to the battery, cables, or starter motor.
For example a battery that develops surface resistance on it's plates only after a couple seconds of cranking. You tested your battery - but did you test it with a load? Try a load test on the battery, keeping the load on for however long you're talking about.
OR... Does it start, then stumbles & almost dies, then gets back to running? In that case fuel stuff would be good to check.
Old Sep 21, 2005 | 07:22 AM
LOGICx420x's Avatar
It sounds like a weak battery from what you say..
Old Sep 21, 2005 | 09:20 AM
Alibi86's Avatar
Looking at what JimBlake says, i think hes got it. It starts the stumbles a little bit and sounds like its about to die on me. Much like when you almost stall a 5 speed. I guess i am going to check the fuel filter and then take it from there.
joehonda1129
Nov 19, 2007 07:53 AM
Vitesse
Aug 26, 2006 01:38 PM
yuckyscum
Oct 25, 2004 06:55 AM
5starJ
Mar 15, 2004 03:41 PM
willyboyK20
10
Aug 4, 2002 03:50 PM
