Starting problem
Old Feb 22, 2010 | 09:59 AM
troyaj2's Avatar
New User
Default Starting problem
Every once in a while I try to start my car and nothing at all happens, no radio, lights, nothing. I then pop the hood, pour a little coke on the positive terminal, try to start it again and I get a rapid fire clicking sound(roommate said this is my alternator), once it is able to click, the radio and lights are able to work. It usually takes a few more attempts to get it to start and then it runs fine. This happens regardless of if I have recently(within a week or so) cleaned the corrosion from my terminals and everything.
Old Feb 22, 2010 | 10:10 AM
davey5300's Avatar
Default Re: Starting problem
throw on a new ground wire and charge the battery. If the battery is more then 4 years old then you should replace it.
Old Feb 22, 2010 | 10:29 AM
troyaj2's Avatar
New User
I had a new interstate battery put in about 6 months ago. I'll try the ground wire though.
Old Feb 22, 2010 | 07:11 PM
nus_dogg's Avatar
To really tell if the battery is bad, you gotta do a hydrometer(Specific Gravity) test which I don't think most people know what it is. If it's got 75% state of charge, you then do the load test. If its below 75% state of charge base on what the specific gravity gave you, you then do the 3 min charge test. All this will tell you if you have weak or bad battery.
But yeah, like mentioned above, get a new ground wire.
General Kills
Aug 21, 2008 12:18 PM
Senbonzakura
Jan 19, 2008 01:54 PM
Heavy Pee
Jul 21, 2003 08:32 PM
EJK
Feb 4, 2003 08:03 PM
2trix
Sep 25, 2002 01:18 PM
