Speedometer Issue
Old Dec 30, 2023 | 10:37 PM
Shawniguess's Avatar
Default Speedometer Issue
I just bought a 94 accord and the speedometer wasn’t working. I read online that it was the vss so I replaced it & the plug & nothing happened. I thought maybe I had wired it wrong, so I flipped the wiring & then the check engine light came on and D4 started flashing. I switched the wiring back, and everything went back to normal but the speedometer still doesn’t work. Please help me.
also no cruise control doesn’t work
Old Jan 1, 2024 | 06:54 PM
LukeM's Avatar
5 Year Member
Default Re: Speedometer Issue
Does you speed sensor have a pair of hoses coming out of it? Have you electrically tested the speed sensor(old and new)? Your gauge could be out.
Old Jan 3, 2024 | 07:58 PM
FastProH's Avatar
Check the connector. Seems that spilling antifreeze from the coolant hose above can harm that sensor. Intermittent problem I would think it’s the gauge
Old Jan 12, 2024 | 07:25 AM
Springlad's Avatar
What could be the reason if the speedometer needle is jumping erratically and only settles at around 40 miles per hour?
Old Jan 19, 2024 | 10:02 PM
brakedrum's Avatar
More often than not, that's because of aged solder connections on the PCB that feeds the speedometer gauge. It's mostly a warm weather (hot day) problem, and goes away when temperature is moderate or cooler. I have a 93 that does it in summer. I'm not bothering to try to fix it by taking out the gauge and trying to resolder the weak joints. I just guess my speed based on decades of driving experience; my guesses are always right. It's even easier if there is a flow of traffic. Just fall in and run where the ones in the middle are.
turbosivtec
Apr 2, 2010 01:27 PM
dapump2003
Mar 14, 2007 01:01 PM
bradly
Jan 2, 2006 05:46 PM
misty_dawn
May 29, 2005 04:18 PM
nightryder21
Audio / Security / Video
Dec 13, 2003 06:26 PM
