Speedometer
Old Jun 2, 2008 | 03:45 PM
noy612's Avatar
Default Speedometer
hi im kinda a newb at cars, but im trying to learn alot. btw i have a 91 accord ex-r 4dr stick shift.i got it for only $500, some minor probs, i fix them. Ive been searching around to fix the speedometer... the speeometer, therometer, crusie and heat sensor on the cluster doesnt work. i heard it would be a loose wire or so, but im unsure... please help
Old Jun 3, 2008 | 03:39 PM
Mr Yamada's Avatar
Default Re: Speedometer (noy612)
The first place to check is Fuse number one / 10 amp, in the dash fuse panel by the drivers side kick panel
Old Jun 6, 2008 | 09:51 AM
Bad_dude's Avatar
Default Re: Speedometer (Mr Yamada)
If the blinkers work then chances are it's not the fuse.
The new speed sensor from the dealer is $189. If you got a friend at the shop then you can get it for around $150. Third party is around $75 but not sure if it would work.
I just got mine changed out for $150 and $35 labor. It's easy to change but just had the dude replaced it for $35.
michael-crxsi
Mar 7, 2010 02:31 PM
jxhxb
Nov 5, 2007 07:05 PM
HCivicSi23
Feb 26, 2007 07:33 PM
