Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: Why is there oil in my spark plug hole?
Guide to diagnose touble and recommended solutions.
Spark plug hole full of oil!! Help
#27
Re: Spark plug hole full of oil!! Help
I had the same problem and my friend had it as well, just replace the O rings, they went bad. If you can do it yourself its an easy $10 fix
#28
$10 in parts and 2-4 hours in labour......that's for someone who knows engines and has a manual to follow. Someone doing it for the first time should set aside a complete weekend as you need to do more than just remove the rocker assembly and replace the O-rings. You also have to adjust the valves....would also be a good time to replace the timing belt and water pump if it hasn't been done lately.
At the very minimum you should get a complete valve cover gasket kit and a Helms manual to do this....
#30
If so then, yes! The 6 x 1.0mm bolts (10mm socket) = 8.7 lbf-ft and the 8 x 1.25mm bolts (12mm socket) = 16 lbf-ft.
VTEC_Du_Ma_Mai
09-06-2008 11:08 AM
VTEC_Du_Ma_Mai
09-05-2008 01:41 PM
