help a noob out on his first engine build
Old Jun 11, 2007 | 08:02 AM
young noob's Avatar
Default help a noob out on his first engine build
hey guys, im getting ready to send my block out to the machine shop, but i have a few questions first, i have a d16y7 that i plan to boost, im on an extreme budget, but i won't cheap out in an area that needs money, i only want around 200 hp, and in the future a max of 300hp, the cylinder walls are messed up, so i want to buy oversized pistons, 75.5mm, when i boost will the walls fall because they are too thin?, should i get a block guard, sleeves? what pistons should i use, what makes vitaras so good, will oem oversized support my needs? its cheaper, will scat rods/tuner toys/eagles rods be compatible with either of those pistons? i have heard sometimes where the wrist pistons goes into it needs bored, but thanks i appreciate all the help
Old Jun 11, 2007 | 08:05 AM
Sound Streamin''s Avatar
Tune it right and the sleeves will be fine. The best defence is to sleeve it, but if you get the tuning right you dont have to. Stay away from block guards.
Old Jun 11, 2007 | 08:21 AM
young noob's Avatar
Default Re: (Sound Streamin')
so you say don't even use a block guard? and what do you think about piston choices? both oversized, but oem or vitara?
Old Jun 11, 2007 | 09:20 AM
young noob's Avatar
Default Re: (young noob)
bump
Old Jun 11, 2007 | 01:17 PM
young noob's Avatar
Default Re: help a noob out on his first engine build (young noob)
ttt
Old Jun 11, 2007 | 01:44 PM
wakedoe's Avatar
Get Vitaras in oversize and *then* take the block to the machine shop, to get it bored. From what I understand vitaras don't fit very snugly, so it might be a good idea to punch the block out to whatever the vitaras need not just blindly go 0.5 over.
Old Jun 11, 2007 | 02:09 PM
young noob's Avatar
Default Re: help a noob out on his first engine build (wakedoe)
no i understand that, my machinist has the block and is taking it apart and waiting for my pistons till he bores, but what i need to know right now is should i get oem oversized or vitara oversized? i only want a max of 300 hp, i want this to be a road racing car, not a highway monster
Old Jun 11, 2007 | 03:30 PM
wakedoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob &raquo;</TD></TR><TR><TD CLASS="quote">no i understand that, my machinist has the block and is taking it apart and waiting for my pistons till he bores, but what i need to know right now is should i get oem oversized or vitara oversized? i only want a max of 300 hp, i want this to be a road racing car, not a highway monster </TD></TR></TABLE>
You're on crack if you think the OEM ringlands would take 300 hp for any prolonged period of time. The vitaras have a much thicker top ringland.
Old Jun 11, 2007 | 06:52 PM
nihad's Avatar
stay away from block guards why.
Old Jun 12, 2007 | 07:26 AM
young noob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakedoe &raquo;</TD></TR><TR><TD CLASS="quote">
You're on crack if you think the OEM ringlands would take 300 hp for any prolonged period of time. The vitaras have a much thicker top ringland.</TD></TR></TABLE>
thats what i needed to know, thanks man, so should i go cp pistons for a little higher compression than vitaras?
and bump again on why i should stay away from block guards?
Old Jun 12, 2007 | 12:28 PM
wakedoe's Avatar
and bump again on why i should stay away from block guards?</TD></TR></TABLE>
http://www.zealautowerks.com/dseries.html says that you're gonna have 8:1 imho that's kinda low for your goals, and could make your fuel economy and off boost performance not that good. But then Vitaras can be had for $150 vs. $400+ for CPs. I say expletive it and just run the Vitaras and compensate with a turbo that will get you to your goal, but just. Like still not overboosted and out of efficiency but the smallest you can run at that power level.
Old Jun 12, 2007 | 02:28 PM
young noob's Avatar
cool cool yea thats what i plan on doing anyway....i have a t25 that im slapping on first, its in my basement......i hate lag and if i had the money i would go all motor......with a b-series of course....... but i thought that vitaras would have gave me 8.5 compression, i guess i have to look into that link
Old Jun 12, 2007 | 04:24 PM
wakedoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob &raquo;</TD></TR><TR><TD CLASS="quote">cool cool yea thats what i plan on doing anyway....i have a t25 that im slapping on first, its in my basement......i hate lag and if i had the money i would go all motor......with a b-series of course....... but i thought that vitaras would have gave me 8.5 compression, i guess i have to look into that link</TD></TR></TABLE>
Iunno that link could be wrong. T25 is kinda smallish so only run it if you don't have to rebuild it first.
Old Jun 12, 2007 | 08:00 PM
nihad's Avatar
why are block guards bad to use.
Old Jun 12, 2007 | 08:13 PM
SovXietday's Avatar
Default Re: (nihad)
75.5mm Vitaras and Eagle Rods, they connect together no problem. I'm not sure if TT is selling their rods right now, I know for quite some time they were remanufacturing the rods. Don't know if the Scat will be plug and play off hand, I went with the Eagles.
Have the block bored correctly. Stock sleeves will be more than enough for your power with a good tune. Some blockguards have the tendency to create hot spots on the sleeve and cause detonation or weaken the sleeves (or both). As far as I'm concerned for that kind of power they're a waste of money, I'm going for 400whp and I have stock sleeves and open coolant passages.
I love my Vitara's, they take a hell of a beating.
Old Jun 12, 2007 | 08:24 PM
JShull's Avatar
Block guards aren't the greatest because of the different expansion rates of the guard itself, the block, and the sleeves. Think about one expanding more than the other. Puts stress on parts that already see more than enough stress as it is.
Old Jun 13, 2007 | 02:41 PM
young noob's Avatar
Default Re: (JShull)
cool sounds good, im excited, i can't wait for some boost! the carbide bits come in tomorrow, d16y7 head is going to get cleaned up baby!
Old Jun 13, 2007 | 05:27 PM
wakedoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob &raquo;</TD></TR><TR><TD CLASS="quote">cool sounds good, im excited, i can't wait for some boost! the carbide bits come in tomorrow, d16y7 head is going to get cleaned up baby! </TD></TR></TABLE>
Don't expletive with the combustion chamber, unless you know what you're doing.
Old Jun 14, 2007 | 10:25 AM
young noob's Avatar
Default Re: (wakedoe)
Don't expletive with the combustion chamber, unless you know what you're doing.</TD></TR></TABLE>
haha thats funny, your right im not going to mess with it caz this is my first head, and i don't know what im doing
Old Jun 14, 2007 | 08:41 PM
JShull's Avatar
Haha I can see it now:
"OH **** I slipped..."
Old Jun 15, 2007 | 03:53 AM
young noob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JShull &raquo;</TD></TR><TR><TD CLASS="quote">Haha I can see it now:
hahaha DICK i told you im not going to mess with it
ge_itr
Jan 8, 2007 09:37 AM
jdm'dc2sc61
Apr 9, 2005 02:13 PM
myDC4rox
Jan 17, 2005 10:35 PM
b_jamin
Mar 19, 2004 02:55 AM
