Smoke coming from breather on head gasket
Old 08-06-2013, 12:44 PM
Preston Doof's Avatar
Icon3 Smoke coming from breather on head gasket
I have a 91 Honda Accord with a F22B1 2.2l Turbo. A few days ago smoke started coming out of a breather that is attached to the top of the head gasket. when i give the engine throttle oil boils through the breather and the smoke smells of burning oil. dont know what the problem is.
Old 08-06-2013, 01:24 PM
GhostAccord's Avatar
Default Re: Smoke coming from breather on head gasket
Do you mean a breather in the valve cover?
A bit of smoke from the vlave cover is normal. It is blow by gases from the cylinders that makes it's way up from the crank case. This is an issue where you will have to look into getting a legitimate oil catch can setup vs just having a breather on the valve cover venting crank case gases into the atmosphere.
If it is smoking really really bad. I would say that you may need a cylinder hone and some new piston rings.
Old 08-06-2013, 05:10 PM
NZXTInerTia's Avatar
If you're boosted you will more than likely need to install a catch can and an aftermarket breather assembly. I'll be plugging my top barb and installing two -10an 90*'s off the back to a twin filter catch can setup here sooner than later. Why would you even be able to see smoke? Do you have the hose hooked to something or a small filter on the barb? Your PCV could also be clogged.
LSXFEIND
04-09-2009 01:26 PM
philkehn
10-25-2006 02:29 PM
whophlungpoo
10-03-2006 10:15 PM
92civichatchsir
12
09-27-2005 10:07 AM
el3vate
11-27-2004 10:34 AM
Quick Reply: Smoke coming from breather on head gasket
