AT shifter cable
Old Oct 28, 2001 | 08:37 AM
CardDealer's Avatar
Banned
Default AT shifter cable
Modified by CardDealer at 4:25 AM 11/16/2006
Old Oct 28, 2001 | 04:04 PM
BreakStuff's Avatar
New User
Default Re: AT shifter cable (schlit)
When the shifter becomes stiff like that its usually the cable in 90&94 series Accords.. I've seen cables become stiff from soda,coffee spilled on the shifter assembly as well..
Old Oct 29, 2001 | 06:02 AM
CardDealer's Avatar
Banned
Default Re: AT shifter cable (BreakStuff)
Old Nov 4, 2001 | 01:41 PM
CardDealer's Avatar
Banned
Old Sep 8, 2004 | 11:17 PM
daver's Avatar
i know this is a reincarnated post, but hopefully beneficial for any searchers.
I noticed that shifter in my '92 auto integra had become very stiff. The extra effort need to slide it btw gear selections caused me to over compensate and blow by the gear selection. Then I went back and forth several times before finding the dumb gear, very annoying.
Didn't know what it was so i disconected the shifter cable from the tranny end. Should be too different from the accord, but i had to remove a chassis crossmember, two engine->tranny stiffeners, and the torque converter housing. then simply remove a cotter pin, once more bolt and it was free.
The good news was the shifter was still stiff, so the tranny was fine. In fact i can easily move the gear changer pin by hand power, with no shift stick leverage.
So next was to remove the cable from the shift lever end. Two bolts underneath, removed the whole lower dash inside, to get the center console off. A little pin/clip, simply, holds the cable attached.
After detachment, i found the shifter free-shifts easily, so its the cable. It feels almost siezed in its sheath. Attaching one end to a vice, i had to put my foot one the bench to get the leverage to slide it.
Gonna order a new one tomorrow, sounds pricey, but it'll be worth it.
And by btw, that cable went downhill FAST.
d
Tic55
Aug 30, 2018 07:07 AM
Mishako129
Sep 6, 2012 03:14 PM
pez1
Nov 17, 2005 08:19 PM
THE GAME IS THICK
Nov 22, 2003 12:51 PM
gumbysix
Jul 2, 2002 11:16 AM
