Shift Lock Problems
Old Sep 8, 2018 | 09:44 AM
DeeFry's Avatar
Default Shift Lock Problems
1991 Honda Accord
Automatic
When you depress the brake pedal the click from the solenoid to let you shift it out of park will not happen, brake lights do come on. Also, when I turn the key to the on position the solenoid under the shifter will sometimes actuate many times (like I'm pressing the brake pedal down and releasing it over and over, without actually touching the brake pedal then it will randomly stop). Is it the solenoid that's going bad? Or is it a switch somewhere on the brake pedal that is going bad? (I've tested both pairs of solenoids on the transmission, lock ups and shift and both pairs are good) I've take my "center console" pieces off so I can see the actual shift lock solenoid but I'm kind of stuck on how to take it off. I cannot pull any codes as I have tried to jump the switch under the passenger side dash but S stays solid and the check engine light comes on but both of them do not blink me any codes. Any help is appreciated!
Edit: Now when the key is turned from the off to the on (not start) position the solenoid will click like you're depressing and releasing the brake pedal every time. Key turned to off position *click* key turned to on position *click*.
Old Sep 8, 2018 | 02:15 PM
DeeFry's Avatar
Default Re: Shift Lock Problems
Okay new information, I think there is a short somewhere or a relay is bad because when the key is in the on position there's a faint clicking noise coming from under the driver side dash that clicks when the shift lock solenoid clicks (to release the lock for the gear shift handle). Does anyone know if there's a relay underneath the driver side dash that controls the shift lock solenoid under the center console by the gear selector? The whole thing sounds like you're pressing on the brake pedal then releasing the brake pedal over and over again.
Old Nov 20, 2018 | 04:41 PM
MazVilla's Avatar
I have the same issue, but let me ask couple of questions:
1. Did you replace the brake light switch? Or do you have brake light when you press on the brake pedal?
2. Does your horn work?
Old Dec 2, 2018 | 07:21 AM
Ranz Sayaman's Avatar
Does anyone know if I can just remove my shift lock solenoid. It seems to be sticking and won’t shift from park, it takes some wiggling around and happens about 3 times a month. If I remove it completely , will that solve the problem? Don’t care about safety
Old Dec 2, 2018 | 09:41 AM
MAD_MIKE's Avatar
MM Gruppe B
Or, you could simply insert your key into the override slot, shift the car int Neutral. And then start the car normally.
Makes for a nice unintentional anti-theft device.
Hondaaccord03
Transmission & Drivetrain
May 24, 2015 05:38 PM
jdmh22eg2
Dec 1, 2012 08:29 AM
geneva
Jun 11, 2008 01:46 PM
b4play
Nov 25, 2007 04:26 PM
yellowdcn
Feb 28, 2005 01:06 PM
