rear hydraulic motor mount vacuum line connection
I bought this accord a week ago and the rear motor mount was broken in half. The car is a 2000 2.3l automatic and has the rear hydraulic motor mount. The vacuum line was disconnected when I bought it and I was wondering if this is the spot wear it is supposed to be hooked up?
This guy is on my firewall and the hydraulic motor mount vacuum line doesn't seem to stretch to it, I can extend it tho if need be. also if this is the wera it connects, theres three nipples the two are open and the one is going to the throttle body. wear is supposed to run to?
Re: rear hydraulic motor mount vacuum line connection
yea a haynes or helms will answer this correctly. lm not a 100% thats a hard to check area to see. but a manual will have vac lines routing and all info
Im pretty sure it is it but you can still feal it jerk pretty good when pulling up to a light or putting it into reverse. any opinions?
VeeSykkz
04-08-2016 11:43 AM
