Accord 1998 Rear motor mount...
Old 08-19-2016, 09:11 AM
dishjuarez's Avatar
Default Accord 1998 Rear motor mount...
Rear motor mount accord 98Where is connected this hose?, my car shakes
Old 08-20-2016, 06:47 AM
user456101's Avatar
Default Re: Accord 1998 Rear motor mount...
It is a vacuum line. If memory serves, on the firewall, on the passenger side, (looking at it with the hood open from the front of the car) it is above and to the left of the motor mount, there is what looks like a dark colored approx. tennis-ball can size "canister". There is a rubber line coming out on the right side of that canister, and then that rubber line connects to a "T" connector. It should connect to that "T".
Old 08-22-2016, 07:43 AM
dishjuarez's Avatar
thankyou bro, do you have a pic of the canister?
Old 08-22-2016, 07:56 AM
ISUBIEXI's Avatar
Am I looking at this wrong or is the VSS missing and the hole filled with dirt?
Old 08-22-2016, 10:39 AM
dishjuarez's Avatar
What is VSS?
Old 08-22-2016, 05:19 PM
ISUBIEXI's Avatar
Vehicle Speed Sensor. The part that reports speed to the speedometer. Also if this is vtec im not sure vtec will engage without it. I have not personally worked on any 98 accords or many automatics so maybe there is a difference. All of the Preludes, Accords and Civics i have worked on have a vehicle speed sensor in that location.
Here is a pic from google.
Here is one from a 99 Accord
This is from an Integra but its a much better view.
Old 08-23-2016, 11:00 AM
dishjuarez's Avatar
the car dont have a "T" conector, need to cut these rubber line and put a "T" conector?
Somebody here have a pic of you hydraulic rear mount conection for accord 1998 automatic?
Old 08-24-2016, 09:25 AM
ISUBIEXI's Avatar
Is the car running and idling ok? If you had a vacuum leak you would most likely idle high.
I was looking and here is what I found. This should give you all the info you need.
Thumping Noise At Cold Start On Honda Accord
Now more important things.... does your speedo work? lol. I checked online and those transmissions should have a VSS.
Having you transmission full of dirt and grime from the VSS port cant be good. I cant imagine your transmission fluid levels are good.
Old 08-29-2016, 08:37 AM
dishjuarez's Avatar
Thanks...
Old 08-30-2016, 06:23 PM
ISUBIEXI's Avatar
Did that page help? It had a ton of illustrations showing the Vacuum routing and where it should be connected.
Old 08-31-2016, 09:28 AM
dishjuarez's Avatar
Yes Thankyou very much,
fxfeguy
03-10-2019 02:35 PM
eddieo
12-26-2017 12:09 PM
civic565
03-21-2011 05:46 PM
mherrcat
02-16-2011 04:17 PM
ExtraBlackRex
11-02-2010 12:08 PM
Quick Reply: Accord 1998 Rear motor mount...
