Quick question
Old May 26, 2013 | 04:45 PM
Zaaj Yaah's Avatar
Default Quick question
I have a 98 Honda accord, v6 not sure of the engine type as it is my gf car...my question is when I drive her car and accelerate I notice the rpm going very high before switching into next gear....sometimes it'll even redline 8k before the next gear....does that happen a lot on these cars or it is just mine... And how would I go on fixing this problem ....thanks in advance...
Old May 26, 2013 | 10:17 PM
holmesnmanny's Avatar
Default Re: Quick question
Are you punching it when it does this ? You could always just back off the throttle.
Old May 27, 2013 | 05:45 PM
grassmarine762's Avatar
manual or auto, could be throw out bearing
Old May 27, 2013 | 06:20 PM
Zaaj Yaah's Avatar
Auto....and I don't punch it..even if I did I doubt it should even.rev that high being an auto and not manual
Old May 28, 2013 | 04:42 PM
Lost Again's Avatar
Being an auto and in this gen...doesn't sound good. Are there any stored codes? Is the trans fluid full/proper level?
No codes and full, you can try a drain and fill - or two or three - with Honda Trans fluid and see if it gets better.
If not, well, sounds like the trans is on the way out
Old May 28, 2013 | 09:12 PM
Zaaj Yaah's Avatar
It was this way a year ago too before I had the trans rebuild...as far as I can remember it as always been like this...hope it ain't the trans....any more thoughts on this...?..and btw I have a Toyota and I read on a yota forum and I remember someone saying something about tightening the throttle wire or loosening it can make the car rev higher...so if I mess with the throttle wire you guys think it might solve the problem?...by doing the opposite of course...
Old May 28, 2013 | 09:22 PM
NZXTInerTia's Avatar
There is a cable running down to the transmission that give the tranny a general outline of how far the throttle is open. Yes, you could try adjusting that.
Old May 29, 2013 | 03:34 PM
Lost Again's Avatar
NZ - No throttle control cable for the trans on the 6th gens - or newer gens
Old May 29, 2013 | 10:49 PM
I've never owned the v6 vtec but I gotta think they are designed to run almost to redline before shifting to utilize the vtec potential. I guess I could be wrong.
I would love to see a video of it acting up.
hokietiger
Feb 8, 2015 12:52 PM
imbest123
Nov 3, 2010 10:17 AM
275Performance
Transmission & Drivetrain
Jan 20, 2010 08:34 PM
wengmc
Oct 25, 2007 07:02 PM
mrgenuine
Honda Civic (2006 - 2015)
Jan 16, 2007 05:15 PM
