question
Old Aug 8, 2004 | 08:25 AM
93accordsleeper's Avatar
Default question
does anyone know where I can send my ecu to get chipped and how much?
Old Aug 8, 2004 | 08:28 AM
madd's Avatar
Default Re: question (Hafler)
its a simple solder job...go to any electronics repair store (preferably something small)...you just have to unsolder the chip thats in there...solder in a socket (and a zif you want one...get all parts before taking it there though) and soler in the chip. the labor shouldnt run you more than ... say $20. we sometimes do it for free...or for %5 or $10...depends on how the customer acts.
Old Aug 8, 2004 | 08:35 AM
Default Re: question (madd)
what is socket and zif?
Old Aug 8, 2004 | 08:40 AM
Im pretty good at soldering is it something I can do myself?
Old Aug 8, 2004 | 08:41 AM
madd's Avatar
ok well i was thinking of doing like an engine management system (uberdata)...you would replace the chip on the ecu with a socket (plug a chip straight in, but can be difficult to plug in..bend the chips legs, etc) so you stick a ZIF socket on top of that (has a lever..like your cpu socket...also you stick the ZIF on top for clearence reasons) then you stick your burnt chip in the ZIF and presto..you can quickly change chips out. if you have a speed chip or some crap like that...i guess you could just solder it straight into the board. solder wick and some flux and a soldering iron, and you could have the chip out in 5 mins. soldering it in would take another 2 min. but if you dont know what you're doing you could **** the board up...but yeah.
Old Aug 8, 2004 | 09:04 AM
it would be so much easier if those little ******* in japan would have puy the socket in right off the bat than we could plug and unplug anytime we wanted
Old Aug 8, 2004 | 09:26 AM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hafler &raquo;</TD></TR><TR><TD CLASS="quote">it would be so much easier if those little ******* in japan would have puy the socket in right off the bat than we could plug and unplug anytime we wanted </TD></TR></TABLE>
unfortunatly those ******* in japan were designing a family car that was fuel effecient and cost effective
chipping a 4cyl with a "Jet" or other sorta off the shelf chip is a waste of money
Old Aug 8, 2004 | 12:28 PM
Default Re: question (fw190bvi)
okyour right but now I have another problem with my 93 accord I took the stock chip out and sottered a socket in like you said and put a mugan chip in now my car want srart any answers, buy the way that was pretty easy
Old Aug 8, 2004 | 12:43 PM
accordselux's Avatar
Me Gusta History
where did you get this mugen chip?
Old Aug 8, 2004 | 12:51 PM
The_Todd's Avatar
Farts in the shower
Default Re: question (accordselux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux &raquo;</TD></TR><TR><TD CLASS="quote">where did you get this mugen chip?</TD></TR></TABLE>
I think in this case
mugen chip= 20hp chip sold on ebay
Old Aug 8, 2004 | 02:00 PM
FatJoe's Avatar
Default Re: question (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">
thats def a good call
Old Aug 8, 2004 | 03:07 PM
JDM.Accord's Avatar
'mugan' is the ****
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hafler &raquo;</TD></TR><TR><TD CLASS="quote">I took the stock chip out and sottered a socket in like you said and put a mugan chip in now my car want srart any answers </TD></TR></TABLE>
Sounds like that 'chip' overloaded your car with horsepower
Old Aug 8, 2004 | 03:26 PM
FatJoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hafler &raquo;</TD></TR><TR><TD CLASS="quote">okyour right but now I have another problem with my 93 accord I took the stock chip out and sottered a socket in like you said and put a mugan chip in now my car want srart any answers, buy the way that was pretty easy </TD></TR></TABLE>
try putting the stock chip back in....
Old Aug 8, 2004 | 03:57 PM
madd's Avatar
Default Re: question (FatJoe)
make sure you lined the key up...you probably have the chip in *** backwards. in most circuits an IC's key is like a half moon. if you are looking at the pins of an IC and the key is facing up (half moon or some dot in the middle of one end of the IC pointing up) the lower left pin is pin 1. very rarely the board will simply give you pin numbers and no key. the pins then count up from the lower left to upper left...upper right and finally to the lower right most pin, which is the last pin.
Kid-jdm-teggy
Engine Management and Tuning
Oct 7, 2014 07:49 PM
BUDtoker
Nov 6, 2007 06:24 PM
BoostedD15B7
Mar 2, 2004 09:29 AM
G U E C O
Jan 22, 2004 08:09 PM
cr-x si
Aug 10, 2003 09:22 PM
