Programing Keyless Entry Fob's
Hello anyone know how to program the keyless entry FOB for a 1998 Accord Coupe?
I was thinking of getting one off ebay because i just purchased a 1998 Accord Coupe and only have one!
Thanks
Thanks
Here's what I've got...
1) Unlock Doors
2) Turn ignition key to "ON" position (II)
3) Press the "LOCK" or "UNLOCK" button on the remote
4) Turn the ignition key to the "OFF" position (0, I)
5) Turn the ignition key to the "ON" position
6) Press lock or unlock
7) Turn key to off position
8) on position
9) lock or unlock
10) off position
11) on position
12)lock or unlock - doors should cycle to indicate successful programming. If you only have one remote, turn ignition to off or don't touch anything. if you have 2+ remotes, go to 13:
13) lock on each transmitter that you need to program
*Steps 2-12 must be performed within 5 seconds of each other. Step 13 can be performed within 10 seconds of step 12.
1) Unlock Doors
8) on position
9) lock or unlock
10) off position
11) on position
Steps 1 thru 12 are done with one remote. Step 13 is where you press the 'lock' button on EVERY other remote you wish to be usable.
CD7; In addition to the remote, there's also an immobilizer chip in each KEY. If you're getting an actual KEY, then the dealer has to do his stuff to authorize the new key into the car's immobilizer.
This has a little bit more detail:
http://www.handa-accessories.c...G.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CD7power »</TD></TR><TR><TD CLASS="quote">i always thought the dealer had to do that well thats what they told me(probably just to get money).</TD></TR></TABLE>Maybe they meant that they are the only ones who can program your keys. Even then, I know a local locksmith has advertised that he can program any key with a chip in it, if you have two working keys.
jdoz22
Oct 19, 2023 12:24 PM
mautryodell
Oct 10, 2017 06:21 PM
jsquared22
Oct 28, 2006 12:47 AM
