Power Window Problem
Old Apr 10, 2007 | 03:08 PM
Rhood's Avatar
Default Power Window Problem
Hi
My driver side window work very slow when going up and some times it stop, I have to wait a second and hit the bottom again and again to get it up is there any adjustment I can do to make the window work more smoothly.
1995 Accord EX
Thanks for the help
Old Apr 10, 2007 | 03:12 PM
hondadude's Avatar
Default Re: Power Window Problem (Rhood)
Try cleaning & lubing the window run channels with silicone spray, if that helps consider getting 'shinitsu' silicone grease from the dealer and smearing it in the window run channel
Old Apr 18, 2007 | 08:38 PM
jonzel's Avatar
I'm having the same exact problem with my 95 integra.
If you fix the problem let me know how.
Old Apr 18, 2007 | 08:49 PM
Nate Graves's Avatar
Can you access the mechanism if you remove the door panel? I don't know how difficult this is on yours, but I had to do it on my '93 to fix a couple other things.
Taking a look at it might help you identify if anything is out of place or needs lubing like hondadude mentioned.
You can take a look at manuals for how to do just about anything to your model car at your local library (or online through the same fashion if they have a website)
Old Apr 19, 2007 | 06:45 AM
Heat's Avatar
I once had that problem on my '99 LX.
First thing to do is to pick up a tube of Shin Etsu silicone grease from the Honda dealer.
Try to clean the channels that the window runs in with q-tips and maybe a little water, let it dry. Then put a bunch of the silicone grease in the channels using q-tips. Problem solved.
Old Apr 19, 2007 | 09:06 AM
Chaos3252006's Avatar
yeah spray it. if you wait too long you'll end up burning out the regulator motor.
Old Apr 19, 2007 | 09:42 AM
5G_Vtec's Avatar
I have the same problem, just on both the front drivers and passenger sides. Deffinitely pick up some Shin Etsu silicone grease. i picked upa tube from Honda, but have yet to do this because the weather has been so crappy.
jessihall
Sep 6, 2010 11:45 AM
oldskoolDA6
May 2, 2008 05:45 AM
4Dinsaneb16
Mar 20, 2007 01:30 PM
OriginalFive
Honda S2000
May 3, 2006 10:11 AM
KEVlN
11
Nov 11, 2005 08:36 PM
