overheating issue
Old Jun 25, 2008 | 01:40 PM
bow tie's Avatar
Default overheating issue
i drive a 96 ex and after running on the hwy and my car is at normal temp, if i let the car run without moving for a while (ie: traffic) i'll notice the temp gauge begin to rise. when the car is moving the temp gauge drops back down. but when i get home i can see the engine used up quite a bit of coolant from the reservior (maximum fill to almost empty). after i refill the problem is solved for a week or two depending if i drive on the hwy or not.
what could be causing me to lose coolant? there is no sign of coolant in the oil. there is a leak on top of the radiator (from a small crack) but that leak should not be able to drain that much coolant, and plus i ghetto sealed it but it still leaks a little. the fan should be working because it turns on when i turn on the a/c. any help is appreciated?
Old Jun 25, 2008 | 02:38 PM
Mr Yamada's Avatar
Default Re: overheating issue (bow tie)
Your statement that the fans are cooling properly because they run with the A/C turned on is incorrect.
The cooling fans are turned on by a thermal switch at the T-stat housing when the A/C is not being used.
MrBigMac
Honda Civic (2001 - 2005)
May 15, 2016 04:25 PM
eman96
Jul 29, 2014 06:53 PM
mrx
Jul 4, 2006 07:44 AM
LoooseGSR
Jul 15, 2003 10:49 PM
DR. ON POINT
Aug 11, 2002 07:42 PM
