overheating
Old Nov 10, 2014 | 12:24 PM
maro's Avatar
Default overheating
I have a 99 honda accord with a f20b in it. Sometimes when the ac is on the car will overheat and if I give it some gas, the needle falls back to half. When the car drive it doesnt overheat only when stopped sometimes. Any suggestions
Old Nov 11, 2014 | 02:54 PM
Lost Again's Avatar
Default Re: overheating
Are you sure the coolant in the rad is at the proper level? Is all of the air out of the system? Do BOTH fans come on when the car is on and the AC is on?
Old Nov 11, 2014 | 06:26 PM
maro's Avatar
Yes I bleed the system and is at the proper level
maro's Avatar
Both fans work when the ac is on
Old Nov 11, 2014 | 06:51 PM
holmesnmanny's Avatar
Sounds like the radiator isnt up to par or has a lot of debris or even the condensor is bad.
Its possible the water pump fins are worn/corroded.
Old Nov 17, 2014 | 04:56 AM
maro's Avatar
I changed the pump 2 months ago. This is just baffling
Old Nov 17, 2014 | 06:56 AM
You need to check if fans are coming on when the car is starting to overheat. Its possible the fan switch is bad.
Old Nov 17, 2014 | 01:34 PM
Tonyeg8's Avatar
I agree check ur fans also make sure the fans are spinning freely and not sticking
Old Dec 10, 2014 | 04:29 AM
maro's Avatar
Just an update. I rodded out the radiator and it fixed the problems. It was clogged
Old Dec 10, 2014 | 10:35 AM
accordturb96's Avatar
pretty common when the coolant is kept up and replaced. Or when people put that stupid stop leak crap in it and too much water
EgHatchy96
Aug 25, 2014 02:26 PM
TODAEG9
Mar 25, 2009 10:05 PM
TODAEG9
Mar 19, 2009 02:27 AM
WillEat4F00d
Aug 19, 2007 03:20 AM
