Opinions on Wheel Spacer's
Old 09-21-2012, 11:56 PM
FRANKENSTIEN813's Avatar
Default Opinions on Wheel Spacer's
99 Coupe w/2inch Drop steelies on the front, would like to get a Wheel spacer kit 4x114 so the front is a little wider stance, maybe 5mm @ most i need to measure first But i was just wondering if any of you have spacers and how did they affect your handling etc?
also, i would want to buy the "spacer" and the extended Lug's , the Bolt on hub kit from ICHIBA Doesn't look so safe with the little bolts and Nuts they got going on there..
Old 09-26-2012, 04:41 AM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: Opinions on Wheel Spacer's
It will effect scrub radius if the wheels are not offset to match the new width.
5mm is too thin to have a spacer with studs. Usually ~25mm spacers are what come with studs. The clamp force of a properly torqued lug nut will be fine. It's the friction between the components that prevents the wheel from moving.
boyong07
01-20-2010 05:05 AM
Kenzo206
10
03-23-2009 10:05 PM
Midori Green
15
01-01-2008 10:39 PM
gakkuken
21
01-10-2005 02:28 PM
9seccivicsi
01-07-2004 05:55 PM
Quick Reply: Opinions on Wheel Spacer's
