which one for boost?
Old Oct 11, 2009 | 10:59 PM
black-vtec's Avatar
Default which one for boost?
hey, i've just bought a 96 accord with a blown engine for cheeep..
IDK wich motor will be the best for boost:
f22 vtec, f22 non vtec or f23 vtec.
Im going for stock internal
Old Oct 12, 2009 | 05:38 AM
civic_turbo's Avatar
Default Re: which one for boost?
Id go with the F22B2 non vtec for boost. tough cylinders and non vtec boost friendly although i wouldnt push no more than 8psi on stock internals. My choice would be to tear it down an throw some forged internals in it. save you money in the long run and more boost! All depends on your plans with the car...
Old Oct 12, 2009 | 12:12 PM
black-vtec's Avatar
thanks man,
actully i found an H22 for a good price and i took it,
but do u have any idea how much the F22b2 can do? i heard it can pull up to 250 whp..
Old Oct 12, 2009 | 03:26 PM
P_Adams's Avatar
F22B2. Iron Sleeves, wet deck and available and readily aftermarket parts.
They are dirt cheap and easily located.
The B2 has milder cam event timing which is what you want on a boosted motor. (More Torque and a higher dynamic compression)
The mechanical compression ratio is in the range you want also. Too high and you risk detonation and other ugly complications.
P
Nosman_99
Apr 22, 2010 07:40 PM
PKSPX
Mar 5, 2004 02:59 PM
greengangsta
Jan 2, 2002 12:29 PM
