No speedometer
Old Oct 18, 2014 | 10:31 AM
mysterymatt's Avatar
Default No speedometer
I replaced my vss and tried another gauge cluster and yet my speedometer still doesn't work. Anyone know wtf is going on
Old Oct 18, 2014 | 05:26 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: No speedometer
Are you sure the mechanical part of the VSS is working?
If the gear stripped it will not turn the VSS, no VSS signal, no Speedo.
Old Oct 20, 2014 | 09:07 AM
94 accord typeR's Avatar
check engine light = VSS
no check engine light = speedometer in cluster
try another speedometer my first one was a dud second works fine
Old Oct 23, 2014 | 04:16 PM
Andrew Jones's Avatar
mine stopped working something like 2-3 years ago if not longer. i just use the tach lol
Old Oct 31, 2014 | 01:04 PM
ag_ghost's Avatar
10 Year Member
What year? My son's 90 EX 4 door auto has that issue so we're about to try a new OEM VSS; fingers crossed.
Old Nov 1, 2014 | 12:23 PM
NerfGunner420's Avatar
have you guys even hooked up a dmm to the signal wire at the back of the dash to see if you guys even get a reading. there probably is a break in the wire.
Old Nov 2, 2014 | 05:14 AM
hiwaydog's Avatar
check the contacts in the connector at the vss for corrosion, I had this issue with mine
Old Nov 2, 2014 | 09:22 AM
cctgene's Avatar
You might check your vss to make sure the drive pin didn't fall out when you installed it.
Happen to me once!
Just a thought.
Old Nov 3, 2014 | 03:57 AM
Mine is the gear in the transaxle is stripped.
Old Nov 4, 2014 | 07:58 AM
Known_Offender's Avatar
If the VSS is bad, the cruise control will not function properly or even work at all. I originally swapped the whole cluster trying to fix the speedo issue , but the second cluster also had a bad board. Then I just swapped just the board and the second one worked. My vss and speedo circuit board failed around the same time. When the vss went out after I fixed the board(I got a cel for the vss) the speedo starting jumping again. I pulled a used vss and it fixed it. Hope that made sense and helped....lol....good luck.
I guess my point was that when it was just a bad speedo board on my 94 ex, the speedometer needle didn't move at all. When the vss went bad the needle jumped erradically and sometimes didn't move, and my cruise control control malfunctioned.
Old Nov 17, 2014 | 01:47 PM
ag_ghost's Avatar
10 Year Member
FWIW, a "new genuine OEM" VSS has fixed his speedometer, eliminated the flashing "S" and turned off the bogus CEL. Thanks to everyone for this thread (Yes I realize we threw replacement money at at it instead of a real diagnosis...).
TheShallot
Dec 16, 2008 09:05 PM
civic_66
12
Sep 14, 2008 12:24 PM
kamakaze1
Oct 27, 2006 06:31 AM
mike_h03
Sep 22, 2006 04:59 AM
mmurphy
Mar 24, 2006 10:07 AM
