mystery engine problem.......PLEASE help !
Old Sep 1, 2001 | 10:07 AM
D-SPEED's Avatar
Default mystery engine problem.......PLEASE help !
yesterday right when i was about to pull into the parking garage.... something happened to my GSR. All of the sudden it started to have a really rough idle ( i can feel it shaking more than normal), there is very little power, and it makes a distinctly more rough / poping sound. The CEL is not on......i tried pulling the ECU fuse and reinstalling, but still same thing........any help is greatly appreciated......thanks
Old Sep 1, 2001 | 11:53 AM
vteg's Avatar
New User
Default Re: mystery engine problem.......PLEASE help ! (D-SPEED)
How long ago was your last tune up. When one of my wires went bad, I drove like 50 miles before I got a CEL.
Old Sep 1, 2001 | 12:23 PM
D-SPEED's Avatar
Default Re: mystery engine problem.......PLEASE help ! (vteg)
i did the plugs and cap/rotor 3k miles ago. I have magnicore wires, which i was told dont last very long. I have a feeling that their time was up. I think it has to do with spark because i can smell gas coming out the can. I am going to go buy some new wires and see if that does the trick
Old Sep 1, 2001 | 01:46 PM
nutsack's Avatar
did you check you replace your plugs the same time, and did you gap them to spec?
Old Sep 1, 2001 | 06:11 PM
D-SPEED's Avatar
Default Re: mystery engine problem.......PLEASE help ! (*******)
it was bad plug wires......magnicores gone bad just like that
Old Sep 1, 2001 | 10:58 PM
LostGsr's Avatar
D-Speed I know this will be coming from outer space, but try checking your rotor again. Take a look at the screw that retain the rotor on and make sure its still on. Mines came off not long after I changed my rotor and cause a similar situation as yours. If yours did come off then put it back with some loctite on it.
Jinksys
Mar 15, 2010 05:09 AM
Faultless18
Dec 9, 2008 01:56 PM
Faultless18
Dec 9, 2008 01:54 PM
kasper
May 26, 2003 03:24 PM
IamVtec
14
Apr 12, 2003 08:10 AM
