need help
Old May 28, 2015 | 12:26 PM
st3v3nm83's Avatar
Default need help
Need help...I have a 2002 accord 2.3 4cyl and its not getting gas to the motor...It will run if you pour gas in the motor... I had a problem with it dying and I would wiggle the battery cables and it would start back up but ive changed the cable end and now it want....I've checked the fuses, main relay and fuel pump and they are all working fine. Any advice would be greatly appreciated...
Old May 29, 2015 | 09:23 AM
Raf99's Avatar
Default Re: need help
Broken main relay will cause your fuel pump to not turn on. Or your fuel pump is not turning on. Check to see if it is turning on to pump fuel.
Old May 30, 2015 | 09:39 AM
barfo's Avatar
Is your check engine light on?
Old May 30, 2015 | 10:45 AM
st3v3nm83's Avatar
ive checked the main relay and its good and nah my check igine light isn't on...ive recently changed everything in the front passenger side brakes even the abs wire.. idk whats wrong with it ive checked everything....its something im over looking
Old May 30, 2015 | 11:54 AM
barfo's Avatar
Might be time to take it to a trusted Honda shop.
Old May 30, 2015 | 12:28 PM
PerformanceFirst's Avatar
Fuel filter maybe? You can crack the bolt on the end of the fuel rail and check how much fuel you're getting from the pump when it primes. You should get about a cup of gas.
JdmR-ek
Aug 20, 2014 07:14 AM
ghettoda9
Apr 13, 2011 10:03 AM
teknohatchie91
Apr 15, 2009 11:40 AM
Siegfried
Aug 21, 2006 11:17 AM
Hayasa15
Mar 25, 2003 12:15 PM
