car probelms look got a vid
Old 10-05-2009, 07:28 PM
bryce warburton's Avatar
Default car probelms look got a vid
http://www.youtube.com/watch?v=XKctkc9kTPk
my car wont drive far then dies and it does this just did an engine swap had some loose grounds fixed that and it just acts up
Old 10-05-2009, 07:35 PM
He knows where you live!
TheMuffinMan's Avatar
Default Re: car probelms look got a vid
Engine swap to what and from what?
What did you change/modify?
Old 10-05-2009, 07:52 PM
i just changed the motor out it was bad put same engine in
Old 10-05-2009, 07:55 PM
Did you reuse the ECU or have a new one?
I don't know of any one part that would cause issues like that except for wiring or ECU. Especially if the RPM's aren't actually reflecting the motor revving up.
Old 10-05-2009, 08:00 PM
Two Piece
Go_Race_Your_Self's Avatar
Hmmmm, does it do that at operating temp.?
Old 10-06-2009, 07:24 AM
yea idk we reused the same ecu and i was thinking it was the fuel pump but now it does this
Old 10-06-2009, 07:32 AM
Is the car actually revving like that or is it just the cluster?
Old 10-06-2009, 08:37 AM
no its actually revving like that i just had to use some starting fluid to get it to go
Old 10-06-2009, 05:54 PM
problem found drove it today no problems it was the ground on the driver side on the intake i guess it went to alot fuel pump and cluster ground etc
ef'dup
05-18-2012 05:12 PM
Cpk8287
06-14-2011 07:35 PM
DarkBB4
09-14-2007 01:30 PM
Garage786
03-11-2007 03:00 AM
Quick Reply: car probelms look got a vid
