jacks
Old Dec 13, 2002 | 10:41 AM
PearlWhiteAccord's Avatar
Default jacks
hi,
just wondering, what are the differences between bottle jacks and jack stands???
Old Dec 13, 2002 | 10:46 AM
WhoNeedsVtec's Avatar
Default Re: jacks (PearlWhiteAccord)
ottle jacks ~ driven by pressure its like a pump you have to pump it up, can hold more weight and alittle safter
jack stand is just a stand hard to explain
Do you need pictures?
Old Dec 13, 2002 | 10:47 AM
Default Re: jacks (WhoNeedsVtec)
I thought you guys might like this picture...This is a bottle jack
Old Dec 13, 2002 | 10:56 AM
thanks, which one will u guys prefer when doing the oil change??? since jack stands will need u to jack up the car first...
is bottle jack the same???
Old Dec 13, 2002 | 11:00 AM
TouringAccord's Avatar
H-T Order of Merit
ok, got a quick question.
I went out to my car yesterday to inspect the front suspension and couldn't get the floor jack under it. It's dropped on pro-kits so it's not like I'm slammed or anything, although the front tire is about half flat from the curb. What type of jacks do you guys use? Just wondering cause if you guys use floor jacks then it's probably just the fact that my front tire is about half flat. Thanks.
Old Dec 13, 2002 | 11:11 AM
Nick M's Avatar
Default Re: jacks (TouringAccord)
You can get a flat jack used for sports cars.
Old Dec 13, 2002 | 11:14 AM
H-T Order of Merit
Default Re: jacks (Nick M)
Where can I get one and how much? Thanks
Old Dec 13, 2002 | 11:54 AM
Stew Pidasso's Avatar
Nothing fits under my car. I drive up onto 2x4s and then onto bricks just to get the jack underneath. Then I put it on jackstands, but before I do that I like to drop the car off of the jack and send my radiator flying up through my hood. Well that's what happened last time anyway...
Old Dec 13, 2002 | 01:08 PM
pisces21's Avatar
Default Re: jacks (Stew Pidasso)
hey you live in the city? mebe one day we can meet up and check out each others rides..
Old Dec 13, 2002 | 02:00 PM
Sinisterh22a's Avatar
i used to do that till i just realized that if you dont have a body kit it is easier to take a jack and jack up the middle where your tow hook is on the back and lift the car that way, it lift the back higher but also pics the front up, it pics it up for me just enough to fit a second jack in the front where the factory jack points are.. just my .02 thought it could help
Old Dec 13, 2002 | 02:30 PM
iam7head's Avatar
Default Re: jacks (Sinisterh22a)
anyone know where to change the oil for lightweight weak sauce pump jack?
like those tiny 29.99 one.
Old Dec 13, 2002 | 04:37 PM
smokin rubber's Avatar
Default Re: jacks (iam7head)
why do you want to change the jack oil?
Old Dec 13, 2002 | 11:20 PM
briq4's Avatar
Default Re: jacks (smokin rubber)
If you can still fit the factory cheesy jack under the car, then jack up at the lift point near the front of the driver's door, then you can fit the real jack under the tow hook in the center of the car and jack the car up normally, then before you lower the car remove the factory jack, (in case it moves and might miss the reinforced jack point) lower the car, then use the jack again to raise it enough to get the jack out. Sounds complicate but it's really not.
Old Dec 13, 2002 | 11:55 PM
SiK AcC0rD's Avatar
thats so ridiculous... so what happens when u get a flat tire? SLAM then goes the whole car leaning on that one side and u can never jack that thing up...let along not being able to do it anyways..thats horrible
Old Dec 14, 2002 | 12:05 AM
iam7head's Avatar
Default Re: jacks (SiK AcC0rD)
Agree but it's their car lol.
Dont all oil pump jack need to add oil once a long while?
Old Dec 14, 2002 | 06:49 AM
Mine leaks, but unless I rebuild the seals it will just keep leaking. It works fine now, but when it stops working, I will throw it in the trash and buy another.
Old Dec 14, 2002 | 03:13 PM
jweller's Avatar
Getting under a car that is up on jacks is a big no no. jacks have been known to collapse, especially those $30 ones (no hate, thats what I'm using) Always use a set of jack stands It doesn't take that much longer either, maybe 2 mins max
Old Dec 14, 2002 | 06:51 PM
iam7head's Avatar
Default Re: jacks (jweller)
LOL I makes a great gift for some enemies of mine..lol
94civiccupew/b7
Mar 22, 2014 04:07 PM
Seatown
20
Aug 21, 2006 10:47 AM
H.
Dec 15, 2005 06:48 PM
Seann
Oct 24, 2001 02:22 PM
Darren94ls
Jul 13, 2001 03:05 AM
