installing nitrous on 95 accord
hello i have a jdm accord setup and i have a nitrous kit. any tips? everything i have is jdm compatible so it should work right?? thanks peepz
Re: installing nitrous on 95 accord (schondaman)
Holy Hell!! For lack of a better word. If you're car were a person it would be a Vietnam veteran. I think people are going to tell you to swap the motor. Maybe get another F22 or whatever you have in there for cheap. I've seen F22's go for 300-400. Check Marketplace.
569800 are you kidding a little info on your (jdm setup) would be nice. If your milage is correct then i would say hell run a 150 shot and c what happens cause that things aint got much life left. Sorry i'm not wishing bad upon you but milage is very high especially if your on stock motor.
Re: (Conflicted)
just make sure to retard the timing accordingly. Also, I would use 1 or 2 step colder plugs and go with copper plugs.
What size jet do you plan to run?
