F23 on Spray...
Old Jan 25, 2008 | 06:49 PM
WhiteAcord's Avatar
Default F23 on Spray...
So yeah Im currently running a 75 Wet Shot, And I need to bump it up.
Anyone here run any shot higher than 75 an F23 on the stock motor?
If so, what jets did you use to run...Thanks.
Old Jan 25, 2008 | 09:12 PM
supraccordlx's Avatar
Default Re: F23 on Spray... (WhiteAcord)
75hp is pushing it on stock motor, do you have to ecu chipped for more fuel? you are going to get a lean condition and blow the **** out of it.
Retard the timing, colder plugs, and spray and pray.
Old Jan 26, 2008 | 05:24 PM
WhiteAcord's Avatar
Default Re: F23 on Spray... (supraccordlx)
Ok......You doont really know anything on the Accord then.The F22 is similar to the F23, in which the F22 has been known to handle up to 125 Shots, all day, approximatey about a year, and it ran fine. I know this because I did it.
Now, Ive already took the precautions to keep the motor safe. I just need to know the Jet setup to run a bigger shot. Thanks foryour input though.
Old Jan 26, 2008 | 07:15 PM
Different n20 setups require different jet sizes not knowing your setup how is anyone going to help you? but I know nothing, I forgot.....
Modified by supraccordlx at 8:25 PM 1/26/2008
Modified by supraccordlx at 9:59 PM 1/26/2008
Old Jan 26, 2008 | 10:38 PM
95greenlude's Avatar
i ran a 100 shot on a stock H23 bottom end for months, i'm sure an f23 could easily handle that......
use this to get jet sizes
http://www.robietherobot.com/n...r.htm
slowhatchcali
Feb 2, 2007 06:40 AM
punjones123
Feb 14, 2006 09:09 PM
Squirtin EGsr
Sep 22, 2005 07:42 PM
Creim_si
Jun 24, 2002 08:19 AM
-=TWITCH=-
May 27, 2002 05:11 PM
