Idle Problem
Old Jun 14, 2004 | 10:10 PM
accord115's Avatar
Default Idle Problem
Hello Honda-Techies. I've been having problems with my 98 Accord Sedan. The biggest problem is that I feel a loss of power and hesitation. It just doesn't accelerate as it used to. Also, I notice that often times when I started the engine, the idle goes up and then drops to about 200 and then back up to 800 or 1k. I could feel the drop--it is like the engine is going to die but it does not. Perhaps I need a tune-up? I've added fuel-injector cleaner to see if that may solve the problem. Any ideas what is wrong ? Thanks.
Old Jun 14, 2004 | 11:15 PM
asnboi_512's Avatar
Default Re: Idle Problem (accord115)
vacum leak somwher? check ur hoses
Old Jun 15, 2004 | 05:32 AM
Scissors's Avatar
Sounds like it could be a bad sensor of some kind, probably induction, that's resulting in the hunting idle.
Old Jun 15, 2004 | 05:39 AM
First Honda 1976's Avatar
Could be a clogged PCV valve, it goes into the valve cover and works with vacum, if its clogged up valve will not open to remove pressure from engine. And cause idle problems , check it out pull out PCV from valve cover and shack it if there is no clicking noise it's clogged.PCV should be changed every 30,000 miles . Also Dirty Throttle Body maybe, Go To Honda Dealer and buy HONDA Throttle Plate and Induction cleaner spray can, and spray clean Throttle Body.
Old Jun 19, 2004 | 04:03 PM
accord115's Avatar
Default Re: Idle Problem (First Honda 1976)
Hmm. I don't know jack about vaccum lines or pcv valves. I just tuned it and that did nothing so i guess I'll look into your advice.
Old Jun 23, 2004 | 06:42 AM
marinero001's Avatar
I have the same problem in my 99LX. After much research I came to the conclusion that it is the Idle Air Control Valve. Honda/Acura is notorious for this engine condition. The factory originals are pretty crappy.
A lesser cause to the problem may be the Throttle Position Sensor or the MAP Sensor.
jaydoghondacivic25
Jan 30, 2006 09:01 PM
CRX-SIR
Sep 20, 2004 06:00 PM
jeffk182
Jun 24, 2004 10:47 AM
DsCivicEx
Feb 5, 2004 02:50 PM
rideredorgohome
May 6, 2003 02:41 PM
