how to replace the cap and rotor?
Old Nov 17, 2007 | 09:04 PM
8 9 si's Avatar
Default how to replace the cap and rotor?
Just in time for my 93 Accord SE tune up. However, when I took off the cap, there's no screw on the rotor, yes I did look and compare with the new one I bought, so my question is how do I take the rotor off from the distributor? Any trick? I remember on my 89 crx si, there's a lillte screw to hold the rotor, all I need to do is unscrew it. Please help. Thanks.
Old Nov 18, 2007 | 05:45 AM
BlkChryKord's Avatar
It should just pull off then if there's no screw. I'd get a screw for it though.
Old Nov 18, 2007 | 04:58 PM
AccordJDM413's Avatar
Default Re: (BlkChryKord)
IF THERE ISNT ANY SCREW ON IT THEN I AGREE WITH THE GUY UP TOP IT SHOULD JUST PULL OFF.....
Old Nov 18, 2007 | 10:12 PM
8 9 si's Avatar
I just pulled it off with a little muscle. I've also replaced my fuel filter. And everything went OK until I went for a drive. Car started OK ( no fuel leak what soever, but when I take a test drive on the streets it's just bog down and almost die around 1500 to 2000 rpm. ( it's not die just bog down and I can't go pass 2500 unless I push the gas real hard. And all kind of choking and bogging. Any clue what's going on? Did I messed up my ignition timing? I really don't think so because the car still start fine. Plus I did not remove my dizzy. Help please......
Old Nov 19, 2007 | 04:09 AM
Check for proper timing and fuel pressure. Since those are the only things you touched I'd start there.
Old Nov 19, 2007 | 06:49 AM
8 9 si's Avatar
How do I check these? Please help. Thank you
Old Nov 19, 2007 | 11:24 AM
Go to autozone and get a Haynes manual and a timing gun.
Old Nov 20, 2007 | 09:32 PM
vdg721's Avatar
Default Re: how to replace the cap and rotor? (8 9 si)
When should the cap and rotor be replaced on a 2003 V6 EX? TIA, D
Old Nov 20, 2007 | 09:48 PM
SuShiBoiiii's Avatar
Default Re: how to replace the cap and rotor? (vdg721)
the the owners manual?
LukieLuc
Apr 2, 2007 06:13 PM
superhatchbackbros
May 19, 2005 04:54 PM
Flux
Aug 18, 2003 12:22 AM
del_sol
Apr 17, 2003 07:02 AM
Mike P.
Aug 2, 2001 10:19 PM
