Left engine mount help!!
Old Jan 31, 2015 | 12:26 PM
potatointegra01's Avatar
Default Left engine mount help!!
So I was replacing the engine mounts and when I got to the driver side the bolts that go to the block were loose. I could shake the whole thing. I tried tightening the bolts and nothing.. Anything I could do? Should I re-tap the treads or ?
Old Jan 31, 2015 | 12:32 PM
B_Swapped93's Avatar
Default Re: Left engine mount help!!
remove them while keeping a steady support under the engine and see if its the bolts or the holes, next post which one it is. you will NOT be able to o anything with the engine in the car that space is extremely tight
Old Mar 30, 2015 | 05:25 PM
I tried putting new bolts on and after I would be able to pull the mount off without a lot of force. So the treads inside I think are done
Old Mar 30, 2015 | 05:40 PM
threads on which mount? if it's the driver one just get a new bolt and a nut and use the new nut over the stripped one. In the case it's the bolt that's even easier.
Old Mar 30, 2015 | 09:24 PM
No it's the treads inside the block that are messed up
MissKryss
Sep 3, 2018 10:12 PM
MyWhiteEJ6
Jul 9, 2013 12:09 PM
lsvtek
Sep 29, 2008 11:45 PM
Boostless97Lude
Apr 29, 2003 01:13 PM
